P1000 mjn's build thread
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
How do those jack nuts work?
Like a drywall nut. In this case, I drilled holes in the inner bed sides, (with corresponding holes in the alumimum plate). Push the jacknut into the hole, thread the bolt into the jacknut and tighten... the portion of the nut that's behind the bed wall crumples up and squeezes itself against the inside of the wall, and viola! You've got a caged nut to thread into.
Works like a charm.
russknight
russknight
1,916
7,542
Perry Florida
Works like a charm.
Thanks!
Reactions: BWAF
mjn
mjn
1,409
5,206
Well, I took the time to remove the bedside panels last night. My powdercoat guy has the stuff coming, so sometime in the next week or so, I should be able to mount 'em back up and be done with that project.
Going with a low gloss black hammer coating. That looks like it'll match the black on the bed the best. Trying to make it look like it "belongs".
mjn
mjn
1,409
5,206
I’m pretty stoked about how these turned out. Very functional, and they look like they belong.
Still have to finish bolting one side down, but other than that, this project is done!
F6AE2D14 1D84 4A79 99C9 49D5711ADE97
B472010C 6D8D 40DB 8318 18F4EFB86665
08AD6327 9532 4332 9FAF EB7588EAF3E4
B2CD3D1B 60FB 47C3 ABEA 155804EC45AF
4A25E14E B977 4C40 92F6 08656C4E45D5
649B5E9B C87B 4BBA B26A 3C29F41D4559
319,890
mjn
mjn
1,409
5,206
Thanks dude! I already knew it worked good, as I've had it mounted in there for a couple months.
The powder coat is about as close as I could get to the crinkle black of the bed. It's not a perfect match, but its not bad. I think as they both get dirty, they'll look more alike. I just hope the coating holds up to use. Guess we'll see.
P
Polcat1979
Vinton, Ohio
Finished the fan install today.
I decided to use light weight aluminum angle.
First, I cut a piece for across the top. I put a 90 at the end so I could attach it to the frame there too. I used a Chevy u-joint cap to attach the angle to the round tube.
Next, I made a box around the fan, added a support on the bottom so it would stay where I put it.
All in all, I think it turned out okay.
View attachment 109602 View attachment 109603 View attachment 109604 View attachment 109605 View attachment 109606
How is the under seat fan doing at keeping the heat away?
mjn
mjn
1,409
5,206
After getting sent the wrong wheels, and then jacking around with the seller for 2 weeks, I have a tracking # for my new wheels. It says anticipated delivery is this coming Thursday... I'm hoping they show up tues or weds. If they do, I'll have them on this week.
