P1000m5 Moparornocar's Long Overdue Build Thread
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
s*** just got real!
IMG 20160810 145054638 IMG 20160810 145037196 HDR
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Hey CP, did you cut 4.5 out if the b and c pillars? I took 5.5 out of the a pillar, wasn't sure what math you used to match them up.
319,736
I
I don't know if l'd have the balls to try this,I 'v got to give you credit for going at it.Hope it goes as planned for you.
Whatcha talking about @iowaguy? You were the first person to do a caged p5-4. You got hell for it yet did it anyway and it came out sweet!
319,736
Ya that was the most I could go within reason. The center post will be a the worst but it know you know. You have to deal with that upper flange that's welded to the b post. I just cut that weld and pulled it back enough to get at the post but it's a pain to weld under. Might be easier to cut through it and reweld
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
Awesome. Thanks. I'm sitting here trying to visualize the b pillars. If I cut 4.5 it looks like it will get into the curve. And I ran out of welding wire. Shcrap. Got the a pillars welded up at least.
Reactions: pct
iowaguy
iowaguy
624
1,424
Eastern Iowa
I
Ya I know ,but everything I did , only put 3 -3/8" holes in the sxs,everything else slid into the frame rails, or clamped on,I really have to give you 2 credit for doing this.I could just see me telling the wife I f###ed up and have to order a new roll bar!
319,736
It does just a little. You'll have to cut a few welds top and bottom just a hair. It does get into the curve a very little bit and you'll have to grind a little on your interior sleeve. I'd get everything lose before welds it has to flex just a bit Lower I b I cut long and came back and trimmed the upper seatbelt mount then put that on as a cap if that makes sense
Reactions: pct
319,736
thats funny
Reactions: moparornocar
319,736
Best pic I could find. If you look the very top of the seatbelt brace was cut about 3/4 as well as the upper brace should be as it's easier (I didn't I just folded then folded back)weld back side of b post throw a little paint on it then replace the upper section of seatbelt brace weld and your back in. This is why I say 4 1/2 is really max without getting into heavy s***. You can see I did get into the round slightly maybe 1/4" but do not go more
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
As she sits for today. Out if welding wire and just got word the monster in law is on her way from Illinois
Reactions: CumminsPusher
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,500
Augusta, Wisconsin
View attachment 19900 Best pic I could find. If you look the very top of the seatbelt brace was cut about 3/4 as well as the upper brace should be as it's easier (I didn't I just folded then folded back)weld back side of b post throw a little paint on it then replace the upper section of seatbelt brace weld and your back in. This is why I say 4 1/2 is really max without getting into heavy s***. You can see I did get into the round slightly maybe 1/4" but do not go more
Yeah, I goobered up and cut too much. I'll get the c pillars welded in and then tackle that b pillar
