So, I’d like some full droop measurements between some of us with similar setups and those with diffent setups... Fox shocks, HL lift and SATV a-arms is what I’m running. Jack the rear of the machine up with both tires off the ground. Measure from the middle of the original shock hole (there’s a bolt there with the HL) to the center of the bottom shock eye. Also, anyone else with different setups from stock to just a HL, to HL and fox, 814 guys or shocks and no lift.. or any combo of setup really. I’m curious to see how our setups compare in regards to suspention droop... between my rear cv heat issues and rear axles a failures I’m curious if there’s not a correlation or contact issue. It just seems like something is up. Might be able to save a few axles for some of us.
@Ragnar406 @GlockMeister @nbomar @Windrock1000 @Plumber32 @Smitty335 @Dragon21 @Delton @ohanacreek @snuffnwhisky @joeymt33 @Kilo427 @Hondasxs
