P500 Never ending quest for bags
  • Thread starter Deleted member 3748
  • Start date
Deleted member 3748
I lost two backpacks I had hanging behind the seats when I installed the Tusk rear window panel. So I'm trying a new bag in the front. It's an ATV fender bag with two pockets. Each pocket has adjustable velcro straps. I think this will be a decent solution.
$18 at Amazon
Amazon.com: Kwik Tek ATVFB-B, ATV Fender Pack (Black): Sports & Outdoors
IMAG01003
IMAG01001
IMAG01002
IMAG01000
Reactions: Dp5hunter
Deleted member 3748
I have one of those for my trailer. :) I definitely need to find a smaller one for the 500.
39,104
I slid a piece of flat bar stock behind each headrest and attached my bag like yours to that.. worked well!
Oh...
I attached it by placing a piece of rubber behind each end and wedging it in.. I then placed two 70lbs cup magnets on each end so it wouldn't scoot or vibrate out.
IMG 1446 IMG 1447
Deleted member 3748
I've never really used those nets until last October. I was surprised how well it worked.
Just make sure you get one with hooks that can be removed and placed in different locations so you can keep the net tight.
Removable hooks is a must or you'll never get it untangled!
Reactions: JTW and joeymt33
Deleted member 3748
Oh...
I have a super strong magnet out of an industrial tool motor. It's a little dangerous if you're not ready for it. Is that what those 70 lb. cup magnets are like?
Reactions: JTW
You could say that.. I made a mistake of playing with them to see how attracted they were to one another. I thought I was going to have to cut that wedge of finger off!! It literally jumped 8 inches out of my hand and firmly bit my finger!
IMG 1449 IMG 1448
Deleted member 3748
Then those should work just fine! I sometimes use mine to pick up nails or screws when I can't find them on the floor.
hambone
hambone
154
89
Southeast Indiana
$18 at Amazon
$18 at Amazon
I hung a bag like that in the center, you can maybe see in the pic
Honda
rocmar
rocmar
4,741
5,773
4 CORNERS
get the ATV tank bag.....
then bolt them to inside of doors
only bolt the top...so you can
tip um up..to spray or clean out
....I leave mine open...there deep
great storage...cheap...looks good
...try it
20150805 114641
O
oldfortyfive
595
1,316
Illinois
...try it
I hung the same bags on my doors too, but with paracord. Also hung a saddlebag between the seats. Both work well.
Reactions: rocmar and JTW
pFive
pFive
670
1,267
Greenwood IN
Just an FYI, I stole the net/hammock bag out of my wife's Milan, the one that stretches across the width of the trunk to put items in to prevent them from rolling around in the trunk, it stretches around the back of the cage pretty much perfectly and lets me throw stuff in it while driving if needed (Empty's or whatever.) A few carabiners and its on. Check local junk yards...
Photo20May201020122013204620PM
Deleted member 3748
Update: Still using the ATV fender bag in the middle of the seat. It's perfect. I also added a cooler which works like a console/armrest. I'll get some pics of the whole seat setup when I'm back home.
