YOU may be able to wrap your foam frame with aluminum foil before you start with the fiberglass resin (if your doing resin). I've used this on several different side projects...I'm only 1 dog beer. You're on the right thought process. I was wondering who'd get that, leave it to the race car guy! Foam hates solvents so there lies an issue but I'm testing that as the foam takes shape
Soon.Hey, wake up and get to work! Don't you know we're anxiously waiting for today's progress.![]()
Have you seen these?There have been very good suggestions here and honestly many would work. The easiest route I see is to go over the whole frame with tape duct tape would be the best but also masking tape because once sandwiched inside neither should fail the problem though anything you use that could bunch up will be lots of added work later. Sometimes it's best to bite the Bullet up front. Fiberglass is very easy to work with but has limitations.
I figure I'll use waterborne sealer to cover most of the divots but it won't stick to plastics so I'll adhesion promote it then use an epoxy primer as a light base because it really sticks. I want the glass to stick to the foam for added rigidly. I'll show how I'm going about it as I do it so anyone else doesn't need to go through the testing. So it's looking like three steps till glass. Headed to wrecking yard now to see about hardware.i need to figure what's going on the door before glass starts
Also mounting the window obviously is tough it'll be number 3 for problems. The best I came up with is headrest posts from a car. It would be simple to click down and release but to solidify the mounts into the cheesy doors even though can be done will be difficult. Im exploring other options
Just thought they could give you some ideas..Just now lol. Someone could definitely retrofit that to work it would be heavy on the hinges though
Forget the windows and think cameras and dash mount monitor...And thank you. All ideas are being looked so I didn't mean that negatively. I sure wish I could use the window from that!
Yeah whatever!! Where's the ass showing emoji??And thank you. All ideas are being looked so I didn't mean that negatively. I sure wish I could use the window from that!
Forget the windows and think cameras and dash mount monitor...hmmm..more electrical work...lol
Good deal, how much was the bic? LolFinally back to the machine. The wrecking yard didn't exactly have what I had in mind and what measurements needed but we'll make some of it work. Grabbed as much from Honda as I could because well I guess I'm brand specific View attachment 25776
