P500 NOISE & HEAT BARRIER GOOD CHOICE
103,558
I'll be putting mine together within the next few days.
rocmar
rocmar
4,741
5,773
4 CORNERS
Yea, I'm onboard with that! ;)
I'm still looking, but found nitrile rubber 3' x 4' x 1/16" for $30 + $11 shipping.
Got any specs...
most important. .is it
fireproof...I know how a
...tire burns...
NitroxDiver
NitroxDiver
488
918
Concord NC
I'm looking forward to a ride that the heat actually bothers me. Lol seems like every ride I have been on was cold and wet!
156,595
Been researching this pretty good looking for something cheap and suitable. Have come to the conclusion that why just plain old rubber wouldn't work? Everything we're covering has a plastic barrier between it anyway, it's not like were draping it over the exhaust. I have roofers that work for me installing TPO and EPDM all the time. I'm just going to get a cut off and use it. Sh**, even Honda used a thin piece of rubber under the drivers seat. I guess if it melts I'll let you guys know. ;)
Reactions: Miss_Oak
rocmar
rocmar
4,741
5,773
4 CORNERS
Try it...
I don't mind..wat I got. .now
except the mouse bedding in it...
Let us know...I'm game for something
water/mouse....proof
Bad_bowtie
Bad_bowtie
Huge member
2,458
14,697
East Tennessee
I bought a roll of this on Amazon. Its just big enough for the P500 and cheap too. Not rode much since it got warm but will put it to the test in a couple weeks at Windrock.
Amazon.com: uxcell 60cmx100cm 394mil/10mm 6.46sqft Car Heat Block Sound Deadener Deadening Underlay Insulation Mat - Intensive Aluminum Foil Face: Automotive
0603171152
0603171152a
103,558
William
William
1,442
2,887
Flowood MS
Between the mice bedding in it and the mud and water saturating it, I got annoyed and trimmed my heat barrier to where it is only covering the seatbelt area for when my kids ride with me. I'm going to try header wrap this time and see how it works. I will say the heat barrier material works great though!
Reactions: rocmar and trigger
103,558
Reactions: GlockMeister
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
No sticky stuff except for the tape aspect...Would you ever want to remove it to add heat to the cab in the winter or for under the seat access?
Yes in the winter I pull my insulation and enjoy the heat coming up through the seat. This is cut to fit from seat bottom to top of seat back so tape or adhesive backing isn't necessary.
rocmar
rocmar
4,741
5,773
4 CORNERS
rocmar
rocmar
4,741
5,773
4 CORNERS
To me...the heat.../ sound...
Are equally a problem...
gonna.give Glock/Jackal
....ideas & product a try...
mine..seems to be perfect
bedding...material for the mice...
which could be. ..another problem..
....CHEWED WIRES.....
