P1000 Oil leak
jasonvaldez1935
cooper city
Hello all,
My name is Jason I'm from Cooper City Fl. Recently I purchased a Honda Pioneer 1000-5 and have pit 168 miles on it. I store it in the garage and noticed oil on the floor. Did some investigating and found oil coming out of one of the tubes. Can't trally tell if it's from the motor or sub transmission. Any advice?
Thank You
Busta1n2
Busta1n2
5
What came of this? Have a 2021 with same issue but not sure it’s oil.
Reactions: Lady01
N
NZHONDA
6
16
new zealand
Hi Guys, i have the same problem on my 2017 sxs700, there is always a pool of oil on my garage floor, any help would be appreciated, have attached photo, cheers
Thumbnail
Reactions: Lady01
63,392
This photo is had to give comment on.
The tubes in red are coolant lines. Most likely not the issue.
Purple circle..
The black tube is a weep drain. It could leak oil or coolant. Meaning water pump needs to be replaced.
Behind this tube is whee it connects to the motor. A bad o-ring here could cause a oil leak here.
However.
There is oil all above this. Is it worse above somewhere or does it kinda clear up?625bc355ea43b451d98822d18461c2c3
N
NZHONDA
6
16
new zealand
Thank you for the fast reply and help, i think the oil above is just from weep drain as the hose clamp has come off there, i will get in and pull the water pump off and check/replace the o-ring, thanks again for the great help
