P500 Post your rear rack or box. Pics.
dannyboy
dannyboy
The older I get the better I was
31
121
NW Wisconsin
  3. Talon X
Where did u get cargo box that’s kinda what I’m looking for.nice rig
The box is from Tractor Supply Co. and was about $100. A number of members here have them, that's where I got the Idea. It works well.
wjhonda
wjhonda
17
maryland
KIMG0185
KIMG0188
This is my rear. Just completed my build. The rear was the last step. I had it custom made at a local welding shop. It's all aluminum with black powder coat. Very light and very strong.
papermaker
papermaker
134
588
Lewiston, Idaho
Harbor Freight had a 25% off coupon and I got the small trailer box and bolted it on. The other three I just zip tied them on so I can take them off to clean or add a gas can.
1511F732 F467 43E8 BB90 2D6E3B047189
Reactions: Glock21user
ctom99
I used blind nuts to mount Rotopax-it comes with all necessary mounting hardware-easily mounted even I could do it. Spare on the top as it is the only way the P5 will fit in my toyhauler. Is it too top heavy ????NO. Hope this helps. We find it safe for our basset hound and our metal detectors and lunch of course. Changes-would not have the rear gate in bottom rack-would make it easier to mount access. And it tends to rattle.
Mike - If you have time, I have another question about your Dusty Dawg carrier. It's hard to tell from the pics you've posted, but would you say your upper basket is plumb with the lower? If I go this route, I'll need the upper basket's floor to be plumb with the P500's rear rack. Just don't want to deal with loose items in the upper basket always wanting to migrate toward the low side. Thanks in advance for your help!
209,843
You need to come to a ride, you will see some really neat 500 beds. Keep an eye on your region for the next ride.
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Here's my set-up for rear cargo.nothing fancy ....I did preserve the wood with green preservative paint...
Did it ever stick ,so i thought i was smart and used some leftover Black rustoleum paint on wood...Bad idea took like a 5 days to dry and stinks like hell ..Now being 1 month later smell is gone and it hard as rock..
I have enough room to put 5 and 10 litre gas cans small cooler and whatever...
20190426 182214 20190426 182229 20190509 162023 20190509 162057 20190509 162103 20190509 162113 20190509 162121
snakeriver
272
596
Clarkston Wa
Spend most of my time on this forum looking and learning. The 500 is such a blank page that the opportunity to take it in a direction all your own is one of it's greatest assets. This thread is very inspirational. There are some really talented folks here. Thanks for your help.
Oh yeah, we've had record setting snow up here in WI. My sympathies to those in or near floodplains south of us.
Nice job, real clean
riderpilot
riderpilot
Southern VA
Here is my hack job. I pulled a part of my deck down and reused the wood to make this. It is help on by gravity and by a few strategically placed 2x4's underneath to prevent it from sliding. I can easily pull it off to go back to the bare rack. Simple, but effective for what I need around the yard.
IMG 1347 IMG 1348 IMG 1349 IMG 1350 IMG 1351
tomcj2
tomcj2
325
731
IMG 3429 A FENCE AROUND OE RACK
I didn't want an enclosed box because within days it would just be full of crap like the back of my van. I built an 11 inch high fence out of 1.5" ABS pipe that is attached to the rack with 6 zip ties so it can be removed easily.
The pipe was scrap from a local plumber and the fittings cost less than $20
riderpilot
riderpilot
Southern VA
View attachment 131698 A FENCE AROUND OE RACK
Are those aftermarket wheels or are they the stock wheels painted?
209,843
Nice! I've always thought chroming the stock steel wheels would look good.
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
This is a great thread- thanks for showing what you’ve built. I’ve though about the possibilities and decided to order a Dusty Dawgs. Mark is sending me pictures of custom mods he’s done when he builds the racks (water/gas brackets, shovel/jack, spare tire). I’ll post with his permission.
I bought a Strong Made 252 basket for the front hood. Last elk season I found it a problem blocking my view of the trail immediately in front- even when empty. We did a 17 mile night ride to pack out an elk which my head was bent-left to avoid rocks and holes on a quad/ snowmobile trail in the national forest.
I re purposed the rack for above the roll cage. It fit great. The 2 rear holes in the bracket attached through factory bolts in the roll cage. I was going to fabricate a plate for the front, but instead used a U bolt and cut it to a J, and wrapped the rollcage with a piece of rubber (from the Honda horn bracket I did not need).
I put a 30” LED light bar on the front. To keep things in, I got 3, 24” bungee cords, cut in half and knotted the cut ends through the expanded metal along the front, so not to lose them when not holding something down.
Here’s some pictures.
7270a94971fd67f2993fec8f30330cbf
F2e6bf84db0ce4cd6aee971f433f5c27
Trider1
Trider1
42
171
Blackfoot Idaho
We prefer something small as we use the heck out of the original rack. This little box stores a helmet, tools, a coat, extra ratchet straps and the dogs collapsible water pail. Everything stays dry and dust free for under $20. All the other necessities are stored under the hood.
20190520 210612 20190520 202635
