P500 Power steering
Mudder
Mudder
NTC/TAP Transition Member
11,883
90,593
Wires with PS ok if that is all you are doing, both back to battery if long enough, (220 watt max draw motor).
Good or bad, used frame for long ground run when did winch previously. I just ran a 6 ga positive for winch to a switched 160 amp fuse beside the battery box, then short heavy lead from batt. Neg. to frame to balance current back to battery. Guess 6 ga. Jumper cables could be repurposed. Removed the skid plate and used wire protection sheath, likely did more effort than necessary, but only wanted to do that one time for future add ons. Connected the PS to that winch supply. Enjoy that PS, but it does limit what else you can add under the hood.
RumpRocket
189
295
USA
I guess this photo is the best....it show's hooking up to the battery.... P500 - Power steering install
JollyJoker
JollyJoker
92
192
Minnesota
Just wanted to let anybody know that is on the fence about buying power steering (or anything else needed). If you buy today 3/09 on e b a y
and use coupon PSPRING20 you will get 20% off. I purchased the tusk power steering for $397.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Finally got the power steering installed. Been in the garage for two weeks waiting for time to do it. Fought long and hard to get the clearance on the master cylinder to work, still grazes it every once in a while when it all flexes... anyone else have this issue. Its clearing lock to lock, then randomly it flexes a bit and touches the edge..
196,417
I was able to keep mine clear. Sounds like you may need to turn the unit a touch more.
Reactions: Mudder
Wallace
Wallace
Well that didn't go as planned
2,813
15,101
Lonoke Arkansas
I think I had to put a ratchet strap on mine and pulled it over, then tightened everything up.
Shadesmn
Shadesmn
505
959
Ramsey, MN
That may be what i do when i get hone i think. I pushed and pulled as much as i could, but still touches just a brush by if it flexes the mount plate..
Shadesmn
Shadesmn
505
959
Ramsey, MN
@Wallace, well the ratchet strap seemed to do the trick. Thanks for the heads up. Was going to call a buddy for an extra set of hands after work if i couldn't get it to work.
