P1000 Radiator fan override
39,079
Has anyone put in a switch to manually override the radiator fan?
On my Honda Foreman, I have a switch where I can leave the fan in auto or turn it manually on or manually off for deep water crossings.
Just checking to see if anyone has done this before I try to figure it out.
63,560
Shouldn't be hard to do. Take pics.
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Would be super easy just have to wire a switch in parallel to the relay so u can send power like designed or at your command
39,079
When I get back from Panama and then get back from vacation at royal blue I’ll start to work on this.
39,079
if your by the canal take a few pics of it and the new extension if you can please
I think they’re expanding it right across from the hotel but it’s hard to see. I did take this picture today...
5b1f11c07539d9a6b57821e72d47106f
Next time I come down here I need to bring the drone and get some better pictures
O
oldgasser
77
Arizona
Hi Joey: By coincidence I just got through doing this on my 2017 1000-5 LE. The most aggravating thing is that the fan controller isn't where the Honda Service Manual says it is. I don't know about earlier models but the 2017 has a storage compartment under the drivers seat. After removing the side cover you have to remove the storage compartment and the PCM and the fan controller are inboard from the compartment held by rubber straps. I had to do this because while Quail hunting with this nearly new machine I got an over heat warning. After letting it cool off I realized that the radiator fan was not running. Got it back to camp and trailered it home because the nearest dealer is 125 miles away. After doing all the service manual diagnostics I came to the conclusion that the fan controller had stopped working so I spliced into the fan leads (blue + power) (green/ground). I installed a double pole single throw switch and mounted it through a hole in the vertical plastic shield below the drivers seat. The switch is directly in front of the PCM. I decided to use a double pole switch and switch both the power and the ground because there doesn't appear to be a permanent ground to the fan motor so it must be controlled by either the PCM or the fan controller. Anyhow I'm taking it back to Quail camp tomorrow confident that my over heating problems shouldn't come back.
39,079
Thank you for this information!
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
My 2017 1000-5 has overheated on me twice because fan didn't come on I believe. Did this resolve your problem, I'd like to install manual switch as well if it did
O
oldgasser
77
Arizona
Since I installed the manual switch I have had no further incidents of overheating. In fact I haven't gotten any warmer than 2 of the 4 segments on the visual temp monitor. I notified my dealer and they have ordered a fan controller module to install when they do my clutch and cabin heat upgrades. I am not certain but I thought the fan came on automatically once or twice so the problem with the controller may be intermittent.
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Have you burped the air out of your cooling system most have had the same issue and fixed it after it had the air removed
brad-1000-5
brad-1000-5
60
97
Bowling Green, ky
Yeah, I pulled up on an incline started engine with reservoir cap and radiator cap removed. 20 minutes at warm temp-2 bars on temp indicator- I then installed radiator cap and drove 5+ miles up and down the road to further remove air. The last overheat was this past Saturday, so a little time will tell I suppose. Thanks for the reply
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
Hello, I am New Here I have a P1000-3 with about 170 miles on it went trail ridding past week end and it over heated once going up a good size hill all was clean cooled down quick but not positive fan was running when that happen, in short has anyone put an over ride switch on fan and if so does it cause any issue with ecm or ground, I guess I am asking for a little more details on how to, Thanks,,,,
39,079
This has been something on my to do list but it hasn’t been very important for me so I haven’t done it yet. I’m not sure if it’s going to cause any issues or not.
I see that your vehicle is low mileage. The coolant system probably needs to be burped. Using a lift, tractor or the winch try to elevate the front quite a bit and start the vehicle and it should purge out any air in the system. The fan may not run when there’s air in the system because it doesn’t get a true temperature reading they say.
I’d try that first before trying to do a fan override switch.
Reactions: Plumber32
208,013
It's always bugged me that the fan doesn't run with the key off, when it's running when you turn the key off?
