Ragnar's Ride And Adventures
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I went through 2 amazon cheap subs that I had installed under the drivers seat - seems that they would handle the ride vibration fine but water got both. I said that if I ever replaced again I would replace with a wet sounds sub. I did not want to have the Sub in the floorboard as my son will still ride in the middle seat from time to time and no doubt something would happen. So I went with the 8" Wet sounds under the drivers seat. Yes it fits but it takes up all the room. Prior to ordering I even went an built a cardboard model to test fit.
It is still working after Takeover (and we went through a lot of water and mud) only thing I need to do is change some settings - I made all adjustments when the Honda was in the garage (it was cold outside) and I need to go back and adjust the Gain and bass boost when it is outside - both have lots of adjustment left. below are pics when first test fit
IMG 0493 IMG 0494
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Went ahead and pulled the skids tonight. I had kind of planned on doing it after Takeover but really did not want to. Clumps of mud clinging to the the skids. I washed them down really good and will install next weekend. Plan on tipping the Honda angled on its side to spray the bottom off and maybe if I am ambitious enough I will run a few wires while the skids are off for future projects.
40738A03 0A3E 48EB 99E8 3B3096AC2996
14256516 26AE 46A4 8373 20A926D4A2A8
B3F0ABA9 DD9D 427C 8263 1C1809B8B792
Any thing else I need to look for and check while these are off?
nbomar
nbomar
4,416
17,854
Springdale, AR
Go ahead and check the air breather tube bolts. No harm in making sure no leaks there. I checked mine while there were off.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
This past weekend was more maintenance
  • Replaced the Hard top off with my screen top from Spidershade for the summer.
  • Installed BCF harness Bar
  • Changed out the Dif fluid and put in Syn 75W-140 and just a little lucas oil stabilizer
  • Tilted over and washed the underside really good
  • While the Skids were off I went ahead and ran a few extra wires for future projects while also cleaning up the existing wiring running under the floorboard. Had I know all that I would eventually do I would have run just one big loom in the beginning.
  • Reinstalled the Skid plates - if I do this again I think I might order all new hardware I did reinstall with anti seize this time.
IMG 1135
IMG 1146
Still need to reconnect my interior lights that are on the middle rops
E
elkguide
3,377
7,963
Vermont
View attachment 74741 View attachment 74742
What are you charging for a "MAJOR" cleaning?
Looking good!!!!!
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Looking good!!!!!
I don't know I still cant seem to get mine clean lol every time it dries there is still dirt everywhere. I would like to find a hot water power washer I could rent once to see if that makes a difference. Need to find a local car wash with hot water to try it.. Granted I really only want to clean it really good once a year.
E
elkguide
3,377
7,963
Vermont
Dirt everywhere means that you've been somewhere!!!!!!
Keep on riding!
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I completed the Door mod and went ahead and cut a hole in the rear panel on the drivers side. My original idea was to but red buttons on here and call it out as where the first aid kit was.... however I think it is easier to say "go get the red bag clipped on the passenger seat bar" than to explain how to access the panel and where it is to someone who does not know this is there - in an emergency.
So I am using this pocket to house some frequently used items that I used to store in the rear seat foot well (that usually got covered in some mud) I am housing my Tire plug kit and my Tree saver and D rings.
Here is the hole empty
IMG 1335
Here it is with the latches installed
IMG 1419
I will take a few pics of the gear inside but basically I have my tire plugs and tools in a zip lock tucked at the bottom of the pocket and then I have my Tree saver and D rings in a dry bag. I may end up moving my tire plugs to where the air compressor is as I figure if you use the plugs you will need the compressor.
NTCPrezJB
NTCPrezJB
President of #NTC
100,007
894,103
Canton, OH
Try a local semi garage or trucking company. They always seem to have the steam pressure washers and a wash bay.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Took time today to replace the brake pads all around, grease the SATV arms where I could, tighten the SATV arm jam nuts - with added Locktight and greased the bearings with an over the axle greaser. I had had a squeak in the driver side rear but that is all gone and the Honda runs with no squeaks at least for now.
O I also replaced the bushing in the steering box and the passenger side tie rod as it had a slight bend in it. Since I had one on hand and everything was off I figured might as well
Brakes - rear brakes needed replacing bad
88143E46 5CAC 402B 8D0C B38947503142 90EB1312 2D9C 41AB AABB 5D3583222DCF 3A5D704A 37BB 4402 9902 A6361CC4C647
Front breaks still had some life in them but they were wore down just below a quarter of the new ones
Pics of the bushing- I can’t really tell if the old was that worse or not but the new one did tighten up the wheel play at lease a little bit.
E3A15D1B A4BA 4138 9C5F 59800DA12C7F 8D0BA232 1705 465F B81A A1AB508C16D2 B9A4204A 06FB 480F B681 FC9D3B193EE2
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
How many miles on it? I may need brakes soon.
Reactions: Ragnar406
nbomar
nbomar
4,416
17,854
Springdale, AR
View attachment 81657 View attachment 81658 View attachment 81659
View attachment 81660 View attachment 81661 View attachment 81662
All that is on my list to get done. I need to order that steering bushing. Can you send me the part number?
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Same package but just different pics Incase the number was glared
EE04523F C0A4 4595 B9D0 163B2D94AA3D 73C68DE0 B728 4DF0 B41A 00CFAF209E81
Reactions: CumminsPusher
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I’ll have to go look but I know you have more miles than me. While I have been in some mud... I would not say that I am in a lot of mud.. but breaking on some of the bigger down hills here with rocks probably wore through them faster as well.
It was crazy to see grass and junk in there around the pads when I will pulling the old off and putting the new in.. lol
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
@Cuoutdoors check you back pads first, those have a lot less material than the fronts. I could have left my fronts on there a little while longer but definitely had to change the backs. I was a little surprised that they had worn down that much myself. If it had not been for a squeak on my last ride I probably would not have thought it time to check them.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I will check them out. Did you get honda replacements or something else?
