RECALL - Honda Pioneer/Talon 2019-2020 Parking Collar / Gear Failure.
63,620
Talon pioneer
3-23-2020
Honda issued a SAFETY RECALL on CERTAIN 2019-2020 Honda Pioneer 1000's and Honda Talon 1000's.
This recall is to inspect for a missing parking collar in the sub-transmission.
PROBLEM - It has been identified that a limited number of units were assembled with a missing parking collar. A missing collar could cause the machine to roll while parked increasing the risk of a crash or injury.
AFFECTED UNITS - Only CERTAIN units 2019-2020 are affected identified by serial number. ONLY a limited number of units will be missing this collar.
NOTIFICATION - Honda will notify all AFFECTED owners in April 2020 via mail.
SOLUTION - The solution will require disassembly of the sub-transmission to replace the missing collar.
HOW TO CHECK MINE - The full list is NOT available to the public. Dealers can check your S# to see if it is affected. The online Honda Recall database is not up to date.
For more info, ask your dealer lookup Service Bulletin dated March 23, 2020, on iN
ProudDadOf5
ProudDadOf5
3,113
24,132
Winfield, WV
  2. Other Brand
3-23-2020
Thanks for the heads up!! I will call the dealer and follow up with them.
At the moment we're being told to borescope the subbtrans through the drain and look for a missing collar inside.
If it's not there, only then will you need to have the sub trans disassembled and have the issue fixed.
ProudDadOf5
ProudDadOf5
3,113
24,132
Winfield, WV
  2. Other Brand
Damn, I just called and mine is due to come in for an anal inspection.. 🤬 Theres no telling when they can get me in. Said they had over 20 to do right now!
5,031
22,492
Can someone tell me the difference in the reverse gearing between the two? - like is the Talon lower/taller? - or beefier?
63,620
A little bit lower.
Reactions: CID
0x48H
0
Earth
Any chance the inspection procedure and/or accompanying video will be posted online? I'd like to do this inspection myself once I know what to look for.
Do you have such a scope?
As of now we have to run VINs to see if yours is affected, there isnt a VIN range yet.
Is this something you can do? If so, this is my VIN 1HFVE06E5L4000590
If not can you tell me where/how to find out if I have an affected VIN? Thank you!
