P1000 Replacing clutch pack on the Beast
Eltobgi
Eltobgi
4,599
15,186
North Dakota
After carefully getting clutch pack and gears reinstall cover. Fits flush without any pounding
IMG 6348
Pay no attention to the oily mess
X4Dice
X4Dice
87
130
USA
Without seeing it in writing within the manual I couldn't do it! I most likely wouldn't be starting it when it is -20 below. If I had to I have heaters that I could put in the engine compartment that would help warm it up a little.
This is the # I called if you are int interested (866)-784-1870. I talked to a person in the pioneer 1000 technical department. I did not get it in writing, he said it would not void the warranty. Maybe I will call back and ask again and see if they will email me saying that it is approved.
Reactions: sharp and Eltobgi
321,218
Looking great!
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
The W number in 0-5-10W-30 stands for winter. So an 0W flows better at cold temps than a 5W. The -30 is the weight at 212 deg. So a 0W-30 and 10W-30 will have very close viscosity at 212 deg but the 0W will flow better when cold.
X4Dice
X4Dice
87
130
USA
The reason that I called honda is that the dealer sold and told me that HP4 (witch is a synthetic blend) is what they recommend for cold whether applications. After reading my manual and it says noting about synthetic I decided to call Honda directly before I pour it into my machine.
321,218
I'm surprised it didn't make you do a transmission reset
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Test successful! Still no U
IMG 6359
@JACKAL @CumminsPusher Can you tell me why my gauge did not appear as your did and whether or not I will need to reset?
Also, all gears work great, auto & manual, including sport mode all work! No issues
321,218
Mine made me do it every time. I'm not positive why yours didn't but I'd sure reset it
321,218
Thanks, all credit to @CumminsPusher i studied his Thread Religiously!
Well I had help by @Hondasxs on write up and @JACKAL posted the reset and @eltogbi did the install give them credit too
