P500 Reverse indicator not working.
rtn001
rtn001
317
945
Central Florida
Started p5 and shifted from neutral to reverse. No movement, bump or indicator light. Back to neutral, shift back to reverse, nothing. Turned switch off. Turned switch on but did not start engine. All lights turned on including the reverse light. Restart engine, shift to reverse, press gas and get movement. It has been going into reverse all along but there is no amber indicator light or other indication of it being in reverse gear. Checked service manual can't find anything about reverse light. I am sure I'm not looking in the correct place. Any ideas and help would greatly appreciated. Going out tomorrow to pull wiring inspection for signs of rodent damage. Just don't know which wires to to check.
63,963
Put it in reverse. What gear does the display say?
Does it give you this [ -- ]?
Behind the battery you will find this plug -[image]. The wires passing through this plug come from the gear position sensor. They also tell the computer what gear the SxS is in.
If the reverse wire is broken, reverse will not work.
The reverse wire is the solid gray one. It runs from the engine case through the plug and to the PCM.
Hope that gets you started.
22433b0a22c6be5a1f915bd0d1a94c5a
rtn001
rtn001
317
945
Central Florida
Yes I do get [ -- ]. I got so hung up on the light I forgot about it. Thanks. I'll check tomorrow.
NTCPrezJB
NTCPrezJB
President of #NTC
101,437
906,088
Canton, OH
I'm looking at a 2017 Camo,also sales man says it's 10 mph faster then any other color....
Some say camo is faster, but you'll never see it. ba da dum tss
We all know red is the fastest. I really don't understand how that other misinformation is getting out there. It must be the Russians!
rtn001
rtn001
317
945
Central Florida
You guys are going to give me a inferiority complex. I had to go outside so Sweet Pea didn't hear any of this and get her feelings hurt. LMAO
13,411
65,699
Nope. Just a crappy photo. You had me looking through. Rats chewed on one of the wire bundles and cut the reverse wire. We're going to have a good old fashion rat killing in this barn if the poison doesn't do it's job.
We had a thread on here with some mouse traps, maybe some of the purchasers can update with their results.
Reactions: rtn001 and Mudwing
