On my p5 heat is really warm where the seat belt locks are.In warm weather I have to keep a rag stuffed in both slots and when warm you run through water and steam will burn you thru there.Any one else's do this.lol
Ya,this is a common problem with the 500's.there are a lot of threads on here with what others have done to cut down on the heat,the most popular is to insulate under the seat and wrap the exhaust pipe.On my p5 heat is really warm where the seat belt locks are.In warm weather I have to keep a rag stuffed in both slots and when warm you run through water and steam will burn you thru there.Any one else's do this.lol
here is what I did and it really made a big difference. Automotive Heat, Sound and Noise Insulation Padding from Amazon.On my p5 heat is really warm where the seat belt locks are.In warm weather I have to keep a rag stuffed in both slots and when warm you run through water and steam will burn you thru there.Any one else's do this.lol
Insulation mat and also I put header wrap. Huge difference.On my p5 heat is really warm where the seat belt locks are.In warm weather I have to keep a rag stuffed in both slots and when warm you run through water and steam will burn you thru there.Any one else's do this.lol
I do not remove it but I did sprayed the material with Kiwi Camp dry Performance Fabric Protector to waterproof it. Going through mud and water dos not affect it much and it does wash nicely. The other side of the material has that heat and water resistant material on it so it will stay protected. Here is the description as shown at Amazon: Automotive heat, sound and noise barrier is a thermal and acoustic insulationI like that idea. Do you take it off when you wash the machine? What about going through mudholes and water, does it get pretty messy?
Go to amazon and get dei 010131 titanium exhaust wrap 2inx25ft cost 25.50.Be sure to get stainless steel zip ties. The mat and the wrap works wonders.Just finished my first ride with this insulation. Very noticeable difference in sound deadening. Not sure about the heat because it's cold and snowing today... yes, snowing in April!
I insulated my machine today. Mine didn't turn out as neat as yours. Hope it does the job. I took it over the engine and exhaust, hopefully it will quiet it down somewhat also.here is what I did and it really made a big difference. Automotive Heat, Sound and Noise Insulation Padding from Amazon.View attachment 12351
The finished project fine and you will be much happier with the heat and noise issues.I insulated my machine today. Mine didn't turn out as neat as yours. Hope it does the job. I took it over the engine and exhaust, hopefully it will quiet it down somewhat also.View attachment 13121 View attachment 13122 View attachment 13123 View attachment 13124 View attachment 13125 View attachment 13126 View attachment 13127 View attachment 13128
That's cool ct, never saw it taken over the rear engine area as well. Has it helped out a lot?I insulated my machine today. Mine didn't turn out as neat as yours. Hope it does the job. I took it over the engine and exhaust, hopefully it will quiet it down somewhat also.View attachment 13121 View attachment 13122 View attachment 13123 View attachment 13124 View attachment 13125 View attachment 13126 View attachment 13127 View attachment 13128
I have not had it out since I did the work Monte. I am hoping that taking it all the way under the rack will help with with heat, noise and dust in the cab. Turkey season starts here next weekend. I will be putting it to the test then.That's cool ct, never saw it taken over the rear engine area as well. Has it helped out a lot?
Great, good luck with that, and the turkey hunting!! I'd like to hear your report when you return.I have not had it out since I did the work Monte. I am hoping that taking it all the way under the rack will help with with heat, noise and dust in the cab. Turkey season starts here next weekend. I will be putting it to the test then.
It's 3'x4". $34.95 at Amazon.Looks great, How big of a piece did u order to do this? Thanks
I also ordered off Amazon. I bought the 4'x6' piece.Looks great, How big of a piece did u order to do this? Thanks
