P500 Seat heat
markie
466
602
milton kentucky
On my p5 heat is really warm where the seat belt locks are.In warm weather I have to keep a rag stuffed in both slots and when warm you run through water and steam will burn you thru there.Any one else's do this.lol
iowaguy
iowaguy
624
1,424
Eastern Iowa
Ya,this is a common problem with the 500's.there are a lot of threads on here with what others have done to cut down on the heat,the most popular is to insulate under the seat and wrap the exhaust pipe.
Reactions: markie
Akfishbum
Akfishbum
121
410
Alaska
I noticed it too but I kinda like the heat......but then again it is almost never more then 70-75 here and most of the time it's below 50 during hunting season when I ride the most. I have seen where people have placed heat shielding under the seat to prevent this.
Reactions: markie
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
here is what I did and it really made a big difference. Automotive Heat, Sound and Noise Insulation Padding from Amazon.
Under Seat Insulation
sthomp54
sthomp54
375
I like that idea. Do you take it off when you wash the machine? What about going through mudholes and water, does it get pretty messy?
Moose308
386
289
Insulation mat and also I put header wrap. Huge difference.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
I do not remove it but I did sprayed the material with Kiwi Camp dry Performance Fabric Protector to waterproof it. Going through mud and water dos not affect it much and it does wash nicely. The other side of the material has that heat and water resistant material on it so it will stay protected. Here is the description as shown at Amazon: Automotive heat, sound and noise barrier is a thermal and acoustic insulation
  • Made from coarse denier nonwoven polyester fiber
  • Laminated scrim reinforced foil on one side and carpet padding exposed on the other side
  • Each unit is 3' long x 4' wide, change quantity for longer lengths
  • Made from Eco-fiTM (100% post consumer recycled plastic bottles) polyester fiber
  • $34.95
There is just enough left that you can install that piece on the inside of the seat bottom panel , (that panel where the hand brake comes out). Just use a spray adhesive on that to keep in in place. The seat insulation part requires nothing but I did use Velcro on the sides and front. It takes just a few second to remove it and put in back on. The wife asked why my butt never go hot before. I should not of said "I don't have as much to get hot."
Deleted member 3748
I noticed the extra hot seat today. The snow is mostly melted and I went through a big puddle of almost freezing cold water. My normally warm seat became a steamy hot seat really fast! Thanks for the tips @Alan , I'm ordering some insulation from Amazon before the outside temperature warms up more.
Reactions: markie
Deleted member 3748
Just finished my first ride with this insulation. Very noticeable difference in sound deadening. Not sure about the heat because it's cold and snowing today... yes, snowing in April! o_O
Moose308
386
289
Go to amazon and get dei 010131 titanium exhaust wrap 2inx25ft cost 25.50.Be sure to get stainless steel zip ties. The mat and the wrap works wonders.
Reactions: Geoff and markie
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
Reactions: cthack
ncred02
ncred02
1,031
1,769
Raleigh NC
I'll be planning on that heat this weekend. The hotter the better this week
cthack
cthack
101
198
Texarkana, Arkansas
That's cool ct, never saw it taken over the rear engine area as well. Has it helped out a lot?
I have not had it out since I did the work Monte. I am hoping that taking it all the way under the rack will help with with heat, noise and dust in the cab. Turkey season starts here next weekend. I will be putting it to the test then.
Great, good luck with that, and the turkey hunting!! I'd like to hear your report when you return.
Reactions: cthack
