P1000 Skid plates without self tapping screws
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
They are Rhino ramps. These are supposedly rated for 5000 lbs per pair, but Id never trust them for that kind of weight. Work great for my Pioneer 1000-3. I think I paid $55/pair. Gives you lots of room to maneuver underneath on a mechanics creeper.
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
Two easy ways to put that one big piece on and off by yourself.
Stand the machine up vertical and use a ratchet strap hooked to front bumper then hooked to front oil drain hole, then you can pivot and slide one handed until you get a few bolts started.
Or use a floor jack to hold it up against frame while aligned with bolt holes.
I cut a couple of 4x4s and wedged them on end under the center section until I got a couple of the bolts started. This project got me thinking about installing an overhead chain hoist in my shop.
Mopower58
Mopower58
TRUMP 2028
88,421
756,459
Crystal Springs,Ms.
Tell me about your plastic ramps, @Prntckt. Are those the Rhino ramps? Standard or Max? I'd likely only use them on the P1K5, as there are a ton of reviews showing them collapse under the load of cars and trucks (what they claim the are for).
Trailer Aid plus are the ramps you want. 15,000 lbs each and plastic.
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
one trick I found works well is to climb the ramps in 4WD lock. Once I did it in turf mode and one of the ramps slid forward. My shop floor is pretty smooth and the rubber tab on the foot of the ramp can slide until there’s weight on it. I think they are safe as long as you use them properly. I think the weight of a Pioneer is far below their safe capacity.
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,259
hondasxs.com
Solid enough for my Pioneer.
20200210 155127
Scoop
Scoop
5,441
21,392
  3. Talon R LV
Would these get my rig high enough to be able to install my new TA skid plates without too much struggling?
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
i just installed a Factory UTV full skid plate on mine using the Rhino ramps, using a mechanics creeper. I wouldn‘t call it roomy, but I was able to do it easily. I did work under it before the ramps (without the creeper), and there is no way I could have drilled and installed all the rivnuts for the skidplate without the ramps.
P1K5Dave
P1K5Dave
2,336
8,719
Petoskey, MI
what size bolts did you use with the rivnuts?
I have been recently replacing my bolts as I lose them, going with 8mm bolts and rivnuts.
I never liked the way they had me drilling and tapping a piece of tube to bolt my skid plate up. So far, I've lost about 5 of those bolts, mostly on the outer edges on my Tusk skid plate.
I do worry a bit about the rivnuts - what's going to happen if you spin one of those suckers trying to get a bolt out? Seems like it's going to be a nightmare in its own right...
283,825
Simply drill out the rivnut and replace, done it a few times with bolts shearing off from rocks.
Scoop
Scoop
5,441
21,392
  3. Talon R LV
I used the bolts from the OEM bolt locations plus the self-tapping screws. The way I figure, I will replace each self-tapping screw with a Rivnut and bolt IF and WHEN it falls out. So far, none have fallen out. Once I do my first post-skid plate install oil change, maybe they will. But it didn't make sense to do elevendy billion Rivnuts all up front if the self-tappers work. So far, so good.
Phantomhunter1
Phantomhunter1
104
578
Ohio
I used M6 bolts and rivnuts with the superatv skid plate. That way all the bolts are the same thread pattern. Many of the superatv skid plate holes utilize the factory threaded holes as well. The rivnuts were from Grainger, item # 33JF21. The bolts were from McMaster 90386A102. I did need a few more that were longer, dont rember length. Maybe 30 or 35mm. Theyre used where the spacer is. Just got those from local hardware.
