Talon Spare tire carrier
Kevinka1977
Kevinka1977
70
73
Washington
That flag mount was in use but now that I had to slide the spare carrier down I cant use it anymore. I ordered a 2" vertical flag mount so I can use a flag on the other side. Now I don't have to remove the flag when I want to get in the trunk.
It's a bit of a struggle for me to swing the rack up to get into the trunk, but I can do it solo. It is heavy and I'm not sure I'd be able to do it if I didn't relocate the RotoPax mount to the bed extender. The spare weighs over 50 pounds and the 2 gallon RotoPax is 18 pounds full.
My crude kickstand held in place.
I cut down an old broomstick to hold the tire in place when I'm solo. Not the best solution but it will have to do for now.
I'm seriously considering the Dirt Road Fabrication bed extender with spare tire mount option to replace my JEI spare carrier. Dirt Road Fab has mentioned that the Dragon Fire hitch receiver will work with his bed extender/spare mount but there it a fitment issue with his set up on the 2 seater Talons. Once he has that worked out I'm likely going that route, it's a much better solution for me to be able to access my trunk.
Here's the Dirt Road Fab extender (photo credit to Dirt Road Fab)
dsc_0331-jpg.176750
Thanks for the pics and info. I ordered the JEI so once it arrives I’ll mod a little and see if I can get a gas shock to work and post pics. Thanks
Reactions: Lil_Steve
5,548
25,546
fwiw: Lil'_Steve invited me to the SxS rally at Sand Hollow in November. While there he showed me that he had to clearance the pins on the JEI or they were very tight and needed 'encouragement' to remove. Adjusting the clamps on the roll cage didn't solve the problem.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Yes, I had to elongate the pin hole on one clamp since no amount of clamp adjustment resulted in easy pin removal. Not sure if this is a common problem or mine was tweaked somehow. I bought my Talon slightly used and it came with the JEI spare carrier already installed.
Backfar
35
Ohio
Had no problems with mine, so far im pleased with it..
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Back to the drawing board. I just installed Rokblokz mud flaps so my broomstick no longer works as a kick stand. The gas strut idea is worth looking into.
Reactions: CID
Kevinka1977
Kevinka1977
70
73
Washington
You could always take a pole or anything that’s long enough, put a bolt or pin through it that fits in the ratcheting holes of the high lift jack, and the other end would support the tire when it’s upright.
I have a few good ideas on the gas strut but will have to wait till my spare tire mount shows up to try them out.
5,548
25,546
A 4' (?) piece of rope from the high lift side of the roll bar to the spare would keep it from slamming down on the right side. Once it starts to fall, I wouldn't be able to stop it. :eek: Tied high on the roll bar would put it out of the way for trunk access.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
I could probably get away with a tie down or ratchet strap for now until I come up with something better. I can't help but think I'd be better off with the DRF extender/spare carrier.
5,548
25,546
Since I'll need both a spare carrier and bed extender/tailgate, the DRF unit is most likely where I'll end up. But from a mechanical leverage perspective, and knowing how yer krazie a$$ drives, :eek: the JEI carries the spare 'better' IMO, not hanging off the back. Much like I mentioned how your Rotopax might work the metal mount into fatigue. It's ok if you call me OCD. :p
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Yeah, I thought about that, I'll run it by the Shock Therapy guys in a couple of weeks to see what they think about the weight so far back there.
I don't disagree with you on the potential metal fatigue, but I'm not too concerned with it and it some fatigue does show up it can easily be dealt with.
Gonna call you Sid. ;)
5,548
25,546
CID, all CAPS. :p
Kevinka1977
Kevinka1977
70
73
Washington
Ok I finally got my JEI spare tire carrier and was able to work on it today and install a gas strut to aid in lifting and closing of the spare tire carrier. Took a couple hours of measuring and installation but I’m glad to say it works awesome!
18C03603 D54E 4801 877F DF6C88AE77B6 BC947BE9 4864 4BEE 996D 1F23A2B16F34 1A93A31A 2BB7 4128 AC99 20955E320801
Kevinka1977
Kevinka1977
70
73
Washington
I also have a video of it but looks like I’m not able to post videos on here.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
How does the RotoPax mount? To the wheel with an adapter plate, or through the wheel to the center bolt on the Carrier? A pic would be great!
Thanks
It mounts through the wheel, the mount is bolted to the carrier.
IMG 20191103 103333 XL
I Later moved the RotoPax mount to my bed extender for easier access and to take some weight off the spare carrier when accessing my trunk.
MVIMG 20191116 130454 X2
TalonMatt
TalonMatt
74
156
WA
You can move it up and down a bit.
88E0D6F1 54C1 4DB4 AB0A BF152F4201F4 4F9EF668 935C 402C 973A 0C1703C8C7BD D33003C0 F695 478B 945B 5FDC2CC15F2D
It's a jei.. but had to chop it up and make what I need for my application.
Is there not a spare rack out there that mounts the tire horizontally as yours now is?
