Synthetic winch rope ?
Chooglin
I am thinking about replacing my steel cable with rope. My question is , do I want to get the same diameter rope as the steel cable ,or go with a larger diameter rope ?
My steel cable is 50' x 3/16" dia.
What would you guys recommend?
7,196
27,836
I opted for the 1/4" synthetic rope when I got my Viper. I theres only room for 45 ' when you go to 1/4"
JWB
JWB
2,012
California MD
I've been wondering about this as well. I'm starting to get a frayed spot in the steel cable, and was wondering if the rope would last longer, does it stretch when pulling, and how well it would deal with snow plow use, strength vs. diameter etc....
Reactions: Chooglin
E
elkguide
3,377
7,964
Vermont
I have to change my cable since I've broken it 2 times plowing snow already this winter. My son has had a synthetic cable on his for the last 2 years and hasn't broken his yet. I'm going synthetic.
Reactions: JWB and Chooglin
161,734
I've been plowing with mine for two years now and no problems. Pulled me out of a mudhole last summer too. I was told that if it ever does snap that it doesn't come whipping back at you or your machine like a cable does. I think if they are repeatedly getting wet that it takes its toll on them though.
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
3/16 is ok for a 3,000 lb winch but too small for anything bigger. The winch line rated capacity is based on a straight line pull. With the wrap on a winch drum you can lose up to 25% cable rating due to the bending moment applied by the winch drum as the cable is spooled on. I wouldn't run even a low quality 1/4 rope on a 4500 lb winch on a P1K5. The cable rating should be at least 1.5x winch capacity but higher is better
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Chooglin
Not that I am doubting @JACKAL , but according to Warn , you can use a roller fairlead with rope. They do suggest replacing the fairlead ,before you switch over to rope!!
I am going to remove the rollers and polish them in the lathe, before I switch to rope , just to remove any nicks or burrs on the rollers !!
Screenshot 2018 01 25 08 17 42
13,560
67,524
ultranger has fairleads as well. I have been waiting for their 1/4" line to come back in stock. Just ordered one as a spare.
Reactions: Chooglin
Similar threads
