Synthetic winch rope ?
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
I've been wondering about this as well. I'm starting to get a frayed spot in the steel cable, and was wondering if the rope would last longer, does it stretch when pulling, and how well it would deal with snow plow use, strength vs. diameter etc....
I use synthetic on all my winches. Wire cables fray and I've stuck them clean through my fingers. It sucks. Wire also takes a "set" if you get it in a bind and it will forever have an awkward kink in that spot.
Synthetic ropes will fray a little easier so you need to take the same care you would with steel (or better). I hear they are susceptible to sunlight (UV) although I've never actually had one dry rot. Mostly, you shouldn't "snatch" on a synthetic. They are super strong but they don't like shock loads.
JWB
JWB
2,012
California MD
Yes, click the link in my post you quoted.
Ya, after looking closely at the rollers, I see it could pinch the hell out of the rope in the corners of rollers. When I make the change, I will probably make my own with a larger opening to reduce drag as much as possible, and give it a mounting point for a large diameter roller for snow plow use. Thanks again for the info.
11,400
85,145
Good info on the fairlead vs rollers. Another good lesson from this forum.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Well it looks like all the major points have been covered but I'll add my 2 cents anyway.
1. I'll never use another winch with a steel cable. Several winches came with steel. I through the steel away and put synthetic on right away. I used to use them until they started to fray. The problem is they cut you easily, kink easily, and are much tougher to work with. Oh and when they snap they come trying to whip you in the face.
2 I don't remember if I got 3/16 or 1/4 but I've never broken a synthetic winch rope. I think they are a lot tougher than they say. I've also heard the "dyneema" synthetic is supposed to be pretty good....I keep a spare as cheap as they are anymore.
3. As previously stated check the fairlead. If its rough it will be hard on your rope. I bought one with the fat roller on bottom for picking up the snow plow. Haven't had any issues with the rope getting pinched. works great!
4. The biggest stressors on a rope is getting them wet and dirty, and when they are walked on or abused. That being said, I have done all those things to mine, I don't take care of them or keep them clean, and they've never failed me.....
Moral of the story, buy a synthetic rope :)
swsebek
swsebek
2,854
5,829
pa
I have a steel one and It has been pretty good for me... but during snow plowing some how it got twisted and I'm having hard time pulling it out by hand.now today I'm going to try to hook against a tree and let the weight of machine pull it out....On my vipermax 4500 there is no extra room at all... Think I too will go synthetic...
William
William
1,442
2,887
Flowood MS
I will never own a steel winch cable again... I used mine one time and it is frayed and cut me... my rope will be here Thursday. I’m leaving the rollers on as they are new and I used the roller fairlead with my last winch rope with no problems. And I abused that winch and rope! Syn rope ftw!
161,868
And if it snaps during a pull it doesn't turn into a flying razor blade.
Chooglin
I assume you’ve been using this for a while, are you liking it?
I have only had to use it twice since I have installed it but it's holding up well. I always unwind it from the spool after I go riding , so I can clean it and allow it to dry out. With the synthetic rope , you don't want it rotting!
Great. Was it difficult to exchange, did you have to remove the winch? I’m asking because I want to replace the cable on my 1000 and the winch isn’t real accessible.
Reactions: Chooglin
Chooglin
It would be a whole lot easier if you remove the winch. I had a difficult time removing the old cable , because I was to lazy to remove the winch from the machine. If you remove the winch , it will also make it easier to secure the synthetic rope to the spool !
Damn!!!!! Thanks Chooglin.
Reactions: Chooglin
Similar threads
