Got the twin Rockford Fosgate 300 Punch compacts ready. Same setup as prior. One is two channel 2ohm bridged for the Wet Sounds sub and one is a four channel 4ohm for the 4 Infinity 6-1/2 mids along with additional tweets. This gives true stereo sound through separates above each main seat in the Pioneer and can be adjusted easily if sound is too loud for anyone.
Both amps are true rms ratings, not rated at max, with very low distortion and super efficient. They are designed for this type application. They can handle moisture and high heat but for this application I added efficient cooling fan that cools when bass amp is turned on and also a second that comes on when in box temp reaches 115f. This box that I made fits between the rails above the gas tank and uses pop clips to hold in place and seals itself to the underside of the seat with a rubber gasket.
The whole system was designed to be hidden and take up as much unused space as possible yet be able to give easy access to the equipment and for maintenance.
Getting closer to a full system, starting backwards and working forward, slowly but surely.
