P1000m5 The Rebuild And Life Of "clutch".
320,061
Sub is in!
I ported this into the cab and seals up with a simple shower drain wash out plug. Exact same setup here as PJ had. No reason to change anything.
9B2F09B2 11BD 4A5A 975A EF102A541937
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
E
elkguide
3,377
7,963
Vermont
I'll bet that by the time you pull the drain plug, the sub is really gurgling!!!!!
Reactions: Plumber32 and BWAF
320,061
It’s not for drain just specifically for porting into the cab while dry out. I didn’t have it in at all for the Takeover last year though, my bad! Doesn’t matter though the sub takes it.
8CCE5113 124B 4277 9D85 19EE2A851351
66,489
So the hole with plug is just for ventilation if you go through water?
Reactions: BWAF
320,061
What's that for
It’s a 1200 amp super capacitor that helps regulate voltage. If bass hits it gives the extra juice so the battery doesn’t fall on its face. Keeps the entire system at a steady voltage. Also as a slight reserve.
A capacitor charges at ten times the rate of a battery and much much more efficiently. Light don’t flicker in the slightest while stereo or winch is being used.
320,061
Got the twin Rockford Fosgate 300 Punch compacts ready. Same setup as prior. One is two channel 2ohm bridged for the Wet Sounds sub and one is a four channel 4ohm for the 4 Infinity 6-1/2 mids along with additional tweets. This gives true stereo sound through separates above each main seat in the Pioneer and can be adjusted easily if sound is too loud for anyone.
Both amps are true rms ratings, not rated at max, with very low distortion and super efficient. They are designed for this type application. They can handle moisture and high heat but for this application I added efficient cooling fan that cools when bass amp is turned on and also a second that comes on when in box temp reaches 115f. This box that I made fits between the rails above the gas tank and uses pop clips to hold in place and seals itself to the underside of the seat with a rubber gasket.
The whole system was designed to be hidden and take up as much unused space as possible yet be able to give easy access to the equipment and for maintenance.
Getting closer to a full system, starting backwards and working forward, slowly but surely.
E0D851C2 E952 4818 8ACB EC7B72D11635
BWAF
BWAF
8,857
42,437
Carthage MO
Sweet setup big amps bet is sounds good
320,061
Actually these are really small considering the output power
1B30AC4B 8E3C 40E3 A2E5 6589015C40FC
Reactions: sharp and BWAF
