The good old Cummins days!
A6BB2FBC DB8C 4829 A991 03834199F0A5
Vikes79
Vikes79
SKOL!
12,000
115,409
South Dakota
  2. Talon X4 LV
I will admit that I miss the 2005 2500 Mega Cab 5.9 CTD 4x4 manual truck I used to have. It was the last manual truck I owned. Too bad the body and sub components around the tranny and motor was a total drain on my pocket book in broken parts or rusty panels.
In 2017 when I purchased my current F350 I seriously looked at ordering a Ram with a manual. Unfortunately it meant buying a truck very derated to keep the same G56 from exploding. Essentially I would be buying a new 12 year old truck.
If Ram offered an updated manual transmission to handle the same hp /tq values on the auto, I’d be first in line and be willing to lay down a bit more coin.
Reactions: JTW
The autos are detuned at takeoff and certain points to save the trans. With the slip of an auto you don’t get the same power to the ground anyways. Even with the detuned manual you get more power to the ground when it matters.
Reactions: Mopower58
Vikes79
Vikes79
SKOL!
12,000
115,409
South Dakota
  2. Talon X4 LV
I don’t disagree a bit.
I’m of the belief that the scenarios in which the ecm and tcm actually allow full power are almost impossible in real world scenarios.
Just disappointed that the R+D dollars have not been applied to HD pickup manual trannys....even in a special order capacity.
Mopower58
Mopower58
Unburdened by what has been!
87,619
751,891
Crystal Springs,Ms.
It's called torque management. All pickup manufacturers are getting away from standard transmissions
Reactions: CumminsPusher
