P1000 The Making Of Pete
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Keep the lift and move the batteries down
come on man, you know that's not the same thing... the lift kit is adding directly to the length of the lever arm, but moving the batteries is more in the category of diminishing returns bc it gets averaged with all the other weight... moving the battery doesn't even come close to offsetting the lengthening of the 13" lever arm to 15"... that's an increase of ~15% to a directly proportional variable right there brotha!lol
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I just put the fronts on - rears on order.
Wrote something here. P1000 - Elka shocks
I would have started my own build thread if I thought it would come to this but when I started i figured - who would want to read my build if all im gonna do is add a light bar - lol.
Serious though - after the HL kit, i'm done with mods for sure. Probably. Maybe.
that's funny right thar, I don't care who ye are!lol
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Just don't break out the calculus on me. I might have to pull out that old HP calculator from college. Alright you have forced me to break out and design active suspension for a SXS. Then you could dial up -3 to +3 inches of of lowering or lift front or rear.
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Move the beer too!
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Trail Amor skids? and did you use same sized tires front and back with no rubbing in front? Nice ride! And how'ed you set your adjustments on compression slow and high?
@Smitty335 it is a trail armor skid. and yes, same size tires on front and back... very minimal rubbing on the mudbuster fender flares.
They're currently set at -10 on high speed damping and -14 on low speed... I'm still experimenting to see what works best for me.
212,639
Are you running different setting front/rear and what kind of terrain do you ride, rocks, sand whoops?
212,639
Seems like you would like more low dampening in the front than the back in slow and reverse in high.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I'll probably soften the high speed damping in the front a little more next and see how that feels.
212,639
Never rode sand whoops, I've been told the set up is very different from rocks. Did race a enduro at Draper Air Force Base that was mostly sand and it was very different.
Reactions: PioneerPete
