P1000 The Making Of Pete
PioneerPete submitted a new Garage Item:
The Making of Pete
View attachment 8943 View attachment 8944 View attachment 8945 View attachment 8946 View attachment 8948
Trying to document Pete's transformation. So far he has a hard roof, popout windshield, warn winch, brushguard, rear fender flares, and pyle 500w tube. Almost forgot the control arm guards. Second battery, isolator, pdm, light bar, and cubes to come next weekend. Damyou @JACKAL !! LOL
Hometeam
Hometeam
952
3,815
Normal, IL
Definitely better at home than on a trail stuck in the mud with no other choice!! Glad it worked out!) I need to get some full skids. Which brand did you get and do you like it?
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I went with the Trail Armor. They were a little pricey, but definitely bomb proof. They fit up well, but not perfect. I would have felt better about it if they were $500 instead of $800.
Reactions: Hometeam
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I didnt realize how time consuming this thing would become. Wiring and electronics are 95% done. Still trying to decide whete to mount the red led strip. Its ~6ft long.
Also still waiting on my usb outlet for the switch panel.
Under the hood is complete, although still debating inline fuses on the pdm lead and isolator leads.
20160206 135517
Found a nice out of the way mount for the pdm.
copied @JACKAL on the:
Universal Relay/ fuse auxiliary distribution box jeep, Cooper Bussmann Off Road
20160206 135527
20160206 135538
20160206 135559
20160206 135628
20160206 135659
20160206 135722
20160206 140043
Used the net mounts for the rear lights.
20160206 140023
Reactions: Tot
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Copied @joeymt33 on the dome light. I only did one. Saved the other for later.
20160206 151310
Grounded the stereo to the rops.
Need more split loom wire protector.
20160206 151345
Used one of the net mounts for stereo ground.
20160206 151429
Reactions: joeymt33
CPope
CPope
352
1,151
Pulaski TN
Can you give some details of the light bar and the cube lights? Maybe the brand /model number and where you bought them. I would like to do that same kind of set up.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
OK, I wasn't happy with my first switch plate that my friend made for me, so I ordered one from a professional. Much better fit, and it's powdercoated metal instead of plastic. The holes are also a much tighter fit, so the switch seals are nice and tight.
Here's a pic of the "rats nest"
20160213 170500
And the front view
20160214 134408
Reactions: pct
That's looking good. I wish my wiring wasn't so much of a rats nest.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Has anyone employed the "bus bolt" method for grounding accessories???lol The bottom lead on the bolt (the 6ga) is grounded to the frame, and then most all accessories (except the winch and pdm itself) are grounded on the bolt.
20160213 170840
I should probably go back and heatshrink these leads. At least it would look better.
Reactions: mattmed03 and pct
