P1000m5 The Rebuild And Life Of "clutch".
322,785
What wireless you got I put the warn on mine really like it
I’d like warn but haven’t got it. The Chinese one works well till you loose the remote...
B548B4EA 3FE3 445C AF9A A19DD44128F1
Reactions: Mudwing and BWAF
E
elkguide
3,377
7,964
Vermont
Massively. Also puts a steel plate directly under the suspension mounts so they are protected against rocks. Actually a big fan after I see how it works.
Plate is currently not bolted but gives an idea. It goes all the way across and back of the mounts. Should be solid
Looks really strong...……. Now the question of the day,
HOW LONG BEFORE YOU BEND IT!
322,785
Welding and bodywork done. 4th time rebuilding the front bumper, it’s hard to keep the business end of Clutch up to par. Well you know with all that pavement princessing she does lol.
Red going on.
9F757BFB 6CDC 4FEE AB72 E96B444DDDB2
BWAF
BWAF
I get paid to pass gas
8,869
42,494
Carthage MO
Red going on.
Something has to bend might as well be something your good at fixing;)
popeye
popeye
3,275
14,644
kapowsin, Wa
Red going on.
Those mall parking lots really pay their tolls
322,785
To be honest I only built the bumper so strong for that reason. I’ve cut and and put in new sections a couple times but refuse to over build it so the frame stays safe. Kinda learned that in the trade, yes something needs to give.
The only thing I did reinforce was the d-ring hooks through to the rear brackets themselves. They don’t move around.
BWAF
BWAF
8,869
42,494
Carthage MO
That's what I was thinking. You make one thing stronger something behind it dies
322,785
Originally went with a larger hole in d-ring mount then cut a rubber hose to slip inside tightly to take out slop. It’s worked great to eliminate the rattle and protect the Warn shackles from chipped paint.
BB1895D9 0A47 49E2 AC52 9F536D5AC4FD
Warn fairlead has taken some abuse but quick trimcoat since there. Have a new light bar to install but the bumper is all fixed up for some more abuse. And I’m headed home.
0E2ED7C3 964A 4DC3 9CEB 883693DB52A6
BWAF
BWAF
8,869
42,494
Carthage MO
Looks good back to new
322,785
Thank you buddy. It’s better, was going to wait for winter to polish up the turd but sometimes it’s hard bolting something back on that’s that rough. Only took a couple hours so screw it
322,785
aauman88
aauman88
1,091
2,846
Bumper redo looks great. I have the SATV frame stiffener as well and love it. Even bolted a 30” strap between the two front tabs as a pull point since I bent my last bumper with recovery hooks. Even use the open hole in bottom of stiffener to strap machine to trailer. I’d venture to say it’s best $100 you can spend if you have large wheels and tires
EA978600 AB48 475F A31F 1EA50DA0413F 30C7E659 6851 4A37 B02D 88B55D1F00D4
322,785
View attachment 157632 View attachment 157633
Ya I agree it’s money well spent! Will eliminate a lot of problems.
Finally got my factory stuff moved around enough that mine is all but in. Gotta say don’t buy one if you’re stuff is bent.
My one complaint was the 4 bolts they give to bolt the plate to the frame underneath would hang up on things. Getting some smooth head Allen’s today.
