P1000 "The Scarer"
Welcome @CTDpower. You've hit the ground running with that new Pioneer. It's coming along nicely.
BTW, I first read your screen name as DCTpower which I thought was cool. "Dual clutch transmission" power.
CTDpower
CTDpower
341
807
Gypsum, Colorado
Ha, that would have been cool. CTDpower is a name I've used for a while... Cummins turbo diesel.
Reactions: joeymt33
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Looks great! Love the stereo setup. Me some ideas when it's time to do mine.
CTDpower
CTDpower
341
807
Gypsum, Colorado
My wheel is turned when I go straight and now the front left tire is going bald with an unusual pattern. I believe the alignment is off, maybe the toe in or out, or camber is off too? Any chance you guys think the dealer will do some type of alignment and maybe put a new tire on it for me? It has 141 miles on it and the front tire has like 50% tread left just inside of the center line... it happened so fast I didn't even notice it.
In my opinion, the dealer should replace your tire for you. The chances of them doing that, probably very slim.
CTDpower
CTDpower
341
807
Gypsum, Colorado
Finally got my sub in... 10" sealed box under the driver seat.
20160807 223826
20160807 174135
20160815 165312
20160824 203849
CTDpower
CTDpower
341
807
Gypsum, Colorado
Cheapie 10" dual sub that I bought used for $5. Real deal quality Kenwood kac-3000 amp, 8ga power and ground, 10ga speaker wire. Supposedly 200watts rms at my 4ohms, it might be close to that. Sounds pretty sweet lol.
Reactions: Eltobgi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Nice! I've been considering adding some bass to support my system, but can't use the space under drivers seat due to yellowtop optima being placed there! That would leave the roof or box! So... I'm thinking of a removable setup using 12's in sealed box w/2 kicker 6x9's and amp assembled as one with quick connect power and ground plug and sound cable which would be strapped down in the bed and removed when necessary.:)
CTDpower
CTDpower
341
807
Gypsum, Colorado
I was going to do a two 10" shallow sealed box that would slip between the bed and tailgate that i could remove quick and just put a simple strap right over the top, but it sounds so much better under the seat instead of in the open air. Probably wouldn't sound bad with the rear seats up but that would only be part of the time. I decided out of sight, out of mind was best for me and leave the bed open. What all do you have that you need the second battery? I have 288w front bar, two 18w side pods, 2 18w rear pods, 4 9w dome lights, 8 9w rock lights, 200w pioneer head unit and this 400w max amp for the sub. bought the only thing I don't have is a winch (come along is good enough insurance for me).
Eltobgi
Eltobgi
4,599
15,186
North Dakota
WOW! That is a lot of draw on you factory electrical! I can see from your video that its not all used at the same time and that your factory electrical appears to handle it. I built my system to support current and future electrical needs. Currently, I am running 4 cube lights, 12" led front bar, XK Glow led lighting, XK Glow whips, LED Rock lights, ssv works reciever, 2 x 3" Attwood blowers, Pioneer 2 channel amplifier, Warn 4500 ProVantage winch. In my last build i ran the same but had an additional amplifier and subs (coming soon)!
When i decide to upgrade my LED Lighting or decide to add additional accessories my foundation will already be in place.
I really like your build! Nice Work!
Reactions: CumminsPusher
322,784
A real box! Very nice.
Sent from iPhone
