Trailer help
K
kswaterfowler
945
3,528
Kansas
brother called and has a goose field for the morning and wants me to bring SxS. I haven’t hauled the Pioneer in awhile so trailer has sat since early fall. It’s blowing my running light fuse on the truck. I disconnected the one running light on each side on at a time and still blowing fuses. All wires appear intact and not pinched. Ground was taken off, cleaned, and still blowing them. Ideas? This has me perplexed but must be something easy.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
You got a short somewhere...
Reactions: swsebek
7,139
27,137
Is it a 4 way flat plug?
7,139
27,137
Any marker lites on the trailer? Also check license plat lite.
Reactions: ohanacreek
K
kswaterfowler
945
3,528
Kansas
Yes 2 marker lights. I cut the wires going to them one at a time and it blew the fuse regardless of which one was cut out of the circuit. No plate light. The light from the rear tail light illuminated it.
7,139
27,137
Ok I think it' the brown wire, I know it normally has a few splices. Think starting at front and work your way down the line. I know that' not a lot of help
K
kswaterfowler
945
3,528
Kansas
Did that. I am out of fuses. Only thing left is some low markers under the rear gate. Everywhere you can see wire looks great.
7,139
27,137
Guess those are next. Have a multi meter?
Bradley-Thornton
Bradley-Thornton
684
1,647
Hattiesburg MS
Are you using a regular 2in ball. The thing is this is how the trailer grounds if it has grease or something on it it can cause the problem but not very likely. Also check your truck battery ground and the ground going to the frame.
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,601
Ridgeway, SC
Check under the taillights on the trailer. Several years ago I had a wire pinched under the right side tail light that caused exactly the same issue.
7,139
27,137
On OHMS setting check resistance from trailer ground to the Brown wire in the plug.
7,139
27,137
If low to no resistance I would separate the connections to the Brown wire starting from the rear most connection
K
kswaterfowler
945
3,528
Kansas
GEt the old 0.0 reading from brown to ground. Others are in the teens
7,139
27,137
Sorry I went down for the night! Did you find anything?
7,139
27,137
The pre wired magnetic sets are awesome. I use them when I use anyone else's trailer
