Trailer size
I
Ichybod
159
231
Tucson, Arizona
Do you have enough room with s 12??
I was thinking about that but I thought a 12 would be tight..
Please let me know
Yes, it has enough room for both the Rancher and the P500. I'll post a picture shortly when I get some time.
sgerksinwi
sgerksinwi
203
264
WISCONSIN
That would be awesome....
Does you trailer fave a gate (height)
Thank you for the help
I
Ichybod
159
231
Tucson, Arizona
I built a little gate for it with 2x4s, 12" high.
IMG 0066 IMG 0067
DaddyDubbs
DaddyDubbs
13,906
129,872
I'm looking at an Integrity 6 x 12 enclosed trailer. The inside height is 6 1/2 feet tall. If I my math is right the P 500 is about 6 feet tall...correct?
Hey BamaBound, I have a 6 x 12 enclosed Lark trailer, Inside dimensions are 11'-4" L (13'-2" to V-nose) x 5'-8" W x 6'-6" H - Door is 5'-3" W x 6'0-1/2" H. My 2017 fits fine, open trailer side access door, drive in forward, set brake, exit through passenger side. Tie down on 4 corners and your done. Plus I like the "out of sight, out of mind" concept that no one knows whats inside. I did end up getting the EMP aluminum roof because I didn't think the OEM roof would fit.
Reactions: BamaBoundSteve
doolin64
doolin64
187
278
I need to put some extensions like lwhite571 did until I can find a deal on a 6x10 trailer. 5x8 is just barely sufficient.
P
PNWGuy
I sold my 2014 Ram 1500 earlier this Spring and bought a 2005 Yukon since I needed an SUV more than a pickup. Plus my best buddy Rowdy was beginning to have trouble jumping into the back seat of the lifted Ram. He loves the Yukon.
But, I still had the Polaris Sportsman and the need to haul yard waste and home improvement supplies, so I bought a brand new 6x10 trailer. It is unique in that the rear gate is 2-piece and doubles as loading ramps.
It is very beefy and I have been super happy with it. Luckily, it should also fit my P5 with room for camping gear, but probably not my pontoon boat as well...
IMG 20180622 142324766
V4 CZMvTKm01RqQZFlJTTopk FznrI1gGuCls7O9ZQApX92IB
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
we have a 6'x14' single axle enclosed trailer that has a ramp door opening to short for a P500:(, bought it 12 years ago when all we had was two ATV's and two dual sport bikes to stuff in there.
We also have a 6'-6"x16' tandem axle landscape trailer with ramp that I thought about making a removable enclosed box to fit on it that a P500 would fit into.The box would have barn doors and could be dropped at either house and used as a storage or left on the trailer to haul stuff incognito, it's just an idea still looking into the cost and then finding the time to make it.
Reactions: DaddyDubbs
P
PBishop
40
135
Nova Scotia
i just purchased a new Pioneer 500 and I need a trailer. I read where the P-5 is 103 inches long. Is anyone using an 8x5 trailer with a ramp? I may have to go with the 5x10 or 6x10 if the 5x8 with a ramp won't fit the Pioneer.
I use a 5 X 8 tilt with no sides and works fine. Just tilt and back it up until the wheels hit the very back of the trailer to add a little tongue weight. The emergency brake will hold it in place until you tilt it down. My trailer is a Gatormade.
lwhite571
lwhite571
431
3,575
Central, IN
No, I just drilled holes and used the latch opening that I had. But I don't have that trailer anymore. It was too light. This is what I bought.
20170429 155925 HDR
Signal_rig
Signal_rig
30
107
TN
Shopping for a trailer now. Looking for a 5x10 or 6x10. Any must have options on the trailer? The bigger the wheel size the better? Thanks
11,361
84,634
Full size tires and extra length is good, as a trailer will be so handy for hauling so many other things. Did buy an enclosed trailer from the place by Chicamauga dam, decent experience. Also keep in mind the width and side rail height for door opening swing if that matters. My P500 with 27 inch tires rubs the door bottoms a little on an old open utility trailer.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,903
19,555
Route 66 Oklahoma
I have a 5X10 (Big Tex) trailer. I got the 5' wide as a precaution, because my wife and daughter might have to drive my truck, and they are not used to pulling a trailer. It is no wider than my F-150, which lessens the chance that they will hit something. :) If it has a rail around the sides, be sure and measure the height and compare it with the open height of your drivers door. Mine only clears by about 1" when I get in. I would recommend getting a spare tire. Mine has a 4' expanded metal gate for loading. It is a heavy SOB. If I had to do it over again, I would get a 3' gate, or use some aluminum ramps. Mine has 15" wheels/tires which is pretty standard for that size trailer. You can find them anywhere if you ever need a replacement trailer wheel/tire.
PistolPeteSTL
PistolPeteSTL
12
I'm using a 5x8 flat bed trailer with ramps. It's a perfect fit. I'm using the Erikson ATV E-Track tie downs, with is a chock with strap attachment that holds the tires in place. Very happy with the solution.
Reactions: Gassygordo
