Trailer size
I
Ichybod
159
231
Tucson, Arizona
I have a 12' PJ trailer that is 83" wide. It has removable side rails that are used as loading ramps, so I can side-load my Rancher and rear-load my P500. It is a single axle with a 3500-pound weight capacity. Really handy!
K
kf9ez
29
$2200 out the door with a spare tire. Seem to be good to deal with. I'll know more after I actually get it.
I look forward to your update. I like the size (big enough but not too big) plus the large wheels. It seems like many smaller trailers come with small wheels and 2200 Lb axles. I would prefer "overkill" suspension rather than just enough. Was it a special order or did R and R have it in stock? If special order, how long did it take from the time you ordered it?
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
Its not about the size.....lol...sorry. Couldn't resist.
O
oldfortyfive
607
1,383
Illinois
It's 2999lb rating so it doesn't require brakes. It was a non-standard size, but there wasn't additional charges for building. It was priced between two standard sizes.
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
I wont try to post anymore joking references to teenage sayings...
O
oldfortyfive
607
1,383
Illinois
Finally got my trailer in and up and running..Ended up being $2300 out the door with spare tire ($115) and including the $320 extra for the bifold ramp. The trailer is 5x10 so I only have about 5" on each side when loading. Loading is real easy with that ramp being so long when extended. Added the Ridgid tool box on the tongue. I moved the unit a few more inches forward on the return trip and it towed better. Must have been a little too light on the tongue.
DSC 1219
Reactions: AlR and solrus
Z
zxylene
171
115
Carlisle, PA
Very nice trailer. Yeah remember the p500 is a bit lighter in the front vs rear. My trailer is so balanced I need to back it on or I have no tongue weight.
O
oldfortyfive
607
1,383
Illinois
My goal was to keep things compact and light so I would not need bigger truck. I am planning on two long hauls a year from Illinois to Montana and South Dakota. Trailer only weights about 350lbs.
283,012
I like using a 5x8 trailer with the ramp gate folded over. Those ramp gates catch a lot of wind, so doing this increases my fuel economy on the highway substantially as well as allows me to use a smaller trailer. Just use a pair of ramps to load and unload, much easier than something as high as a pickup bed. :)
2015 01 1920092913 zpsksn2bppr
Did you take Pauly's car?
C7846a0301c36c43e2daade9b34f332a
Reactions: Wayno17
solrus
solrus
1,629
2,511
Montana
Indeed very sweet trailer!
Where in Montana are u going?
Stop by for an elk steak dinner :)
O
oldfortyfive
607
1,383
Illinois
I've got friends and a grand daughter in the Bozeman area. We'll be using it for elk hunting.
solrus
solrus
1,629
2,511
Montana
Nice, I live in Great Falls. Well , if you up for a ride let me know. And by the way shoulder season still open till mid Feb.
Who makes those nice trailers?
P
PaPaCraig04
30
20
i just purchased a new Pioneer 500 and I need a trailer. I read where the P-5 is 103 inches long. Is anyone using an 8x5 trailer with a ramp? I may have to go with the 5x10 or 6x10 if the 5x8 with a ramp won't fit the Pioneer.
I rented a 6x9 Uhaul Trailer with ramp and it was perfect.
Martin
Martin
55
105
Mont-Laurier, Qc, Canada
If you are planning to put tracks on your P5, you will need a 63x123.... even then you will need to modify the tailate a bit since with the tracks it is about 130 inches long by 60 inches wide. just on wheels, 5 x 10 will do.
IMG 0136 IMG 0137
solrus
solrus
1,629
2,511
Montana
I have 4x8 and this is snuggy fit.
lwhite571
lwhite571
431
3,575
Central, IN
I have a 5 x 8 trailer. I put two pieces angle on the two latches that gives me about 4 inches of extra length. The holes fit too.
20160320 164302
NTC/TAP Transition Member
11,865
90,390
Looking to get a larger trailer than my current 13 ft cargo area (single axle). Hauling a P500 and Rancher. Any feedback on a true 16 ft long bed, or the shorter combination side load and rear ramp type. Anyone converted a 13 ft to cut out the sides and wondering if that weakens it for weight of both machines. Local dealer has a 83"wide, dual axle with brake, side load for $1900. Looks like I need 16 ft end to end with both.
I
Ichybod
159
231
Tucson, Arizona
I can carry both my Rancher and my P500 with the 12-footer. As I said, I find it real handy. The dual-axle setup your local dealer has, which I assume is a 16-footer, seems like a decent price.
sgerksinwi
sgerksinwi
203
264
WISCONSIN
Do you have enough room with s 12??
I was thinking about that but I thought a 12 would be tight..
Please let me know
