lwhite571
lwhite571
431
3,575
Central, IN
20160919 125549 HDR
20160919 125702 HDR
20161009 130841 HDR
Feeding the horses
ehart814
ehart814
1,679
3,752
NWPA
Nice! I'm wearing the OEM's out on my 700 before I put new shoes on.
i would too... the original tires on the 700 are much better than what the 500 comes with. My friend's rear tires are toast, and the fronts have plugs and holes an keep losing air so it was definitely time for replacement anyway.
ehart814
ehart814
1,679
3,752
NWPA
Those lights look sweet, do they actually throw good light or just shine bright?
They throw a lot of light. You have to adjust your headlights way down though - with the Hid bulbs the light pattern points to the sky for some reason. very, very easy upgrade. I use the 35 watt kits. I have only had problems with the 55 watt kits. They are not as reliable. That being said, any HID kit is less reliable than the halogen bulbs. I wouldn't have even done this upgrade if I didn't have the light bar as backup. I have a ton of light now.
Reactions: Shadesmn
lwhite571
lwhite571
431
3,575
Central, IN
Can you get LED headlights ? If so, where would I find them ?
lwhite571
lwhite571
431
3,575
Central, IN
Great pics! What's the weight of the big role of hay? How did it do pulling that?
There about 1000 pounds. The 500 did great pulling it threw the mud to get to the place that i put it...
Reactions: doolin64
Shadesmn
Shadesmn
505
959
Ramsey, MN
Did you have to cut away some of the front guards to clear the factory plastic shaft guards? I had too on mine.
Yeah I did. Cut them a few times as they hit different on both sides. After a trim they still hit a bit but flex enough that they didn't seem to bind
Jshell3
My dad installed these very same ones on his yesterday... Aluminum Products. I asked him the same question about cutting any plastic deflector fins... he said he didn't have to cut anything. But I'm not sure if "having to cut plastic" is because of the installation process or if it's a steering/performance/suspension issue afterwards? Could you show me what was cut so I can point it out to his attention? It sounds quite minor at any rate. I'm just confused without seeing it myself...
Plus I'll be installing A arm guards in a couple days on mine, myself.
Shadesmn
Shadesmn
505
959
Ramsey, MN
My dad installed these very same ones on his yesterday... Aluminum Products. I asked him the same question about cutting any plastic fins... he said he didn't have to cut anything. But I'm not sure if "having to cut plastic" is because of the installation process or if it's a steering issue afterwards? Could you show me what was cut so I can point it out to his attention? It sounds quite minor at any rate. I'm just confused without seeing it myself...
Ask and you shall receive. They still hit a bit if the articulation changes but they dont bind as hard against the aluminium now if they do. And you can see they are a bit different in trimming.
20161013 172026 20161013 172033
Shadesmn
Shadesmn
505
959
Ramsey, MN
Dang @solrus, I thought my pics were a quick response. You about beat me to it.:)
solrus
solrus
1,629
2,511
Montana
:) I had them since Feb 8, 2016 :)
Panzer
Panzer
15
50
Menominee, Mi
