Chooglin
Another thing I've been wanting to do (after the Takeover) is get rid of my two rocker switches and replace them with this.
Misw6526 1
It will allow me to control my cube LED lights , rock lights and leave me with one extra position for any other lights or accessorie I may add later , all on one switch !
After I get everything all sorted out the way I want it , I will buy a new dash and have a nice clean look to it !
156,131
That switch will allow you to operate individually and together?
Reactions: Caper
Chooglin
Yes , this is the same switch I have in my 2009 Ford Escape. It controls the headlights, parking lights and fog lights. If you pull the switch out , it controls the fog lights on the Escape (this is the 3rd position).
First position controls the parking lights , second position turns on parking lights and headlights and when you pull on the knob , it turns on the fog lights.
41,748
I was just saying to my wife that I hardly use my brakes. I gear down, mostly. Down steep hills, L all the way. Probably only two stop signs on the dirt road to the trails. After that, I’ll be lucky to see one person on the trails for weeks.
Trying to get my daughter to drive the same way. :)
Did it hurt the rotors ?
Did you Neverseize. Up here, you take something apart, get out the Neverseize. Makes it a lot easier next time. :)
Caper
No damage. Still a touch of pad left. I had just hit the sensors at the end of the last ride .
Normally I use hi temp brake grease (aka the expensive green stuff) on the slides, pad channels, and even on the contact points on the back of the pad (still the best anti squeak I've ever used). On a off road machine...I don't . It just attracts dirt, so I clean the channels of rust and brake clean them and leave them bare. The slides felt good and free, so I let sleeping dogs lie. Boots seem flimsy anyway, so I didn't want to risk tearing them.
Reactions: Caper
Caper
Caper
7,779
10,988
Halifax Nova Scotia
Nice. How long did it take you, start to finish. For the average guy. Unless you’re a mechanic. :)
Caper
Reactions: DG Rider
Caper
Caper
7,779
10,988
Halifax Nova Scotia
Man, your hardcore. :)
I wish I lived closer. Haha
Caper
41,748
Caper
Oh...they aint bad. Maybe 10 minutes a side with hand tools. Only the bottom bolt has to come out. Hold the inner nut or you'll tear the slide boot by twisting it.
That rear boot was a whore. Probably took 2 hours of swearing.
Reactions: Caper and BWAF
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Holy crap that’s a lot of wires.
How long did it take you to in’s the ps . :)
Caper
About an hour and a half, but it’s not complete but I did test it and ensure it was working. Still need some minor adjustments and ECU mounting, but need to layout everything out to support dual battery setup. Guesstimate on time to completion of all wiring 8-10 hrs
NTCPrezJB
NTCPrezJB
President of #NTC
100,338
896,829
Canton, OH
Think it will hold up to the dirt/mud/water though?
Reactions: Caper
Chooglin
I just read this again and NO , each position of the switch will not allow you to control them individually. Each click of the switch will turn on the next accessory while the others still stay on.
Position one is off (like picture)
Position 2 is accessorry 1
Position 3 is accessorry 1+ accessory 2
Position 4 (pull on switch) is accessorry 1and 2 + accessory 3
It's a 10 terminal switch, so it is going to be tricky to figure out how to wire it all :(
156,131
That's what I was wondering, if they'll come on in series? Which wouldn't be bad other than the rear facing lights. @Hondasxs new reverse light harness could solve that issue? ;)
Reactions: Chooglin and Caper
13,346
64,911
Send me the year, make, model, and i'll get you a factory wiring diagram for the switch.
Reactions: Caper
Caper
Caper
7,779
10,988
Halifax Nova Scotia
Caper
Caper
Caper
7,779
10,988
Halifax Nova Scotia
Installed EFI high Winch mount that was the easy part..Routed it along the Main wire harness to the battery was a nightmare...lol
2 days later finally finished....
How many pins did you loose or break. :). I lost two. :). So now I have a bunch extra. Haha. But doing stuff like that, you have to do it right the first time. :) No sense of doing it twice. I did have to move my Contactor when I put my Chooglin glove box in. :) Not a biggie.
Always good talking with another maritime. :)
Caper
Caper
Caper
7,779
10,988
Halifax Nova Scotia
Small fingers. :)
Caper
