Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
194,798
Here's a sneak peek before it goes to Line X and final install.
Fitting up to the tapers and curves and maintaining the body lines, meant nothing really being straight or square to anything else. Radius' and angles up the a**, this thing was a b**** to make! :mad:
Looks pretty BA on the machine though. ;)
Roof Visor
Lilred500
Lilred500
548
1,997
Wv
Here's a sneak peak before it goes to Line X and final install.
You’ve got me wanting to go crazy with some diamond plate your rig looks badass!
Todd627
Todd627
57,252
624,598
MI
Are ya gonna put lights in it too?
Upload 2019 11 2 19 30 50
194,798
Sun visor?
Yeah, roof visor. Figure it might help with the glare on this full shield? Maybe push the rain water past my lap and somewhat protect the light bar too?
Nah, I pretty much did it because I had some diamond plate left and wanted to make something. :D
194,798
Trigger roof visor next? Better start making a few. P/5 guys are gonna want them
I'm sure it would be cheaper and easier to make one from UHMV, lighter too. This thing was far too labor intensive for what it is and keeping the look can be a real pita sometimes. Thanks, but no way man! ;)
194,798
Finished installing a Warn vrx35 and Warn plow/tubes/ mount. Got to practice plowing snow on the Montana driveway, too.
Great product, but bull$hit installation instructions.
Pics?! How wide of a blade did you go with?
Don't know if yours came with any but having plow markers is nice to have.
Plowing
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
60” Provantage blade, push tubes, mount
VRX 35 winch
Warn mounting plate (low in front bumper guard, can’t really see it mounted upside down).
Installation would have been straight forward IF their documentation was not as bad as it is. I saw here the mount must go on first- it’s hidden in a long list of items before the actual installation.
There’s a funky bracket for the ‘contactor’ (relay) that even Warn tech support could not explain why to use it since the ‘contactor’ bracket fit the Honda mounting tabs perfectly.
I got 3 different wiring diagrams in 3 boxes which were different- the spade lugs went down with the large mounting posts/ nuts up. One had picture different. I ordered the dash rocker switch and a wired remote control. I had to use the VRX 45 install diagram, and guessed correctly where a brown jumper wire went. The 4 posts are color coded for the 4 wires- ignore that since they go on different posts than the same color.
Overall pleased- I broke the plastic pulley the first time I tried it. I need to buy a metal pulley to use.
But I got to use the winch. I took the P5 and my 7mm Rem Mag into the Gallatin NF for elk and deer. I learned on a packed snow road with a little ice the P5 slid around. I slid sideways, got myself out (Harbor Freight mini shovel for $6) and turned around. A guy in a GMC Yukon with his son drove past me stopped on the narrow road giving we a wide bearth- and got stuck. We dug and I tried to pull him as he spun all 4 tires with no success. 2 guys on snowmobiles stopped, the dug a little and with 3 guys pushing and rocking the GMC got him out.
I need to buy chains- but I want to put in larger tires next year so may not for the stock tire sizes.
Some pictures as requested.
Acf9c9613a3e7d4be323784864d64c25
57fe2b6ec5fcb98e1f7549f5c7edca5c
48413cce20146b1d2b420cc333aa0527
Rocker and remote control plug. Seemed like a logical place to drill the mounting hole.
6c385617faf141de524d235d7ea898c4
nctrailboss
nctrailboss
440
1,454
north carolina
I added Walker Evans shocks today.It was not a bolt on deal for me.The WE shocks are about 1 inch longer than stock.This caused a problem on the front right.At full droop.the CV joint was binding a bit.[no problem at the other three corners].I assume this is because this is the shortest of the four shafts.I cut the front lower shock mounts off and moved them 1/2 inch out on the A-arms and re=welded.Not much of a change,but it freed up everything.Anyone else check for binding CV joints with the WE shocks?Now,the good part.These shocks are NICE!
DSC01280
NTC/TAP Transition Member
11,859
90,307
It reminds me of a BA version of the electric model. Put a fake battery sticker on the side. But really, wish they would offer just the side access door to make a storage compartment.
9C3EB9FB 51EF 4393 8F8F A4A2B918193E D234539A 90EF 457B A9C8 7096A117495E
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
It reminds me of a BA version of the electric model. Put a fake battery sticker on the side. But really, wish they would offer just the side access door to make a storage compartment.]
Sounds like a product idea ready for Choog to design and sell.
I have been thinking about how to mount an ammo can under the seat for storage and access it from above.
It would be easier to mount 2 narrow ammo cans on either side of my Dusty Dawgs rear rack with bolts and fender washers.
194,798
