16p500
16p500
59
235
Florida
Ended 2019 with the cup holder mod. Opted for the black instead of stainless.
20191231 162204
20191231 172046
196,812
Been ordering bolts and sh** lately for the skids and an upcoming mod and been doing some learning. Just wanted to point out that the Class 8.8 bolts at Home Depot are not Grade 8's. In fact, they don't carry any metric bolts in Grade 8 or even 5 at HD, Menards or TSC either. I had to order them and even then they're not easy to find. Settled for 10.9's which have a similar shear strength to 8's. Big difference though, like 100,000 lb to 838 lbs for the 8.8's. Big difference in price too. They'd be okay for stuff not real important. ;)
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
Moved my plow relay because I’ve got a box on the way!
Also adding a couple of lights for night plowing while I have access to the wiring.
So where dose one put the solenoid so it is out of the way?
I just installed my winch and thought about making a spot for the solenoid but then I didn't want it in the way of a glove box or EPS or the under hood cargo tray.
Then I started thinking about making a tray to hold ammo cans instead of the cargo tray.
Finally decided to use the Honda bracket since I will end up moving the solenoid several times anyway.
196,812
Mounted mine on the firewall when I first got the machine, not knowing there was a place meant for it on the frame. Actually worked out better, after all the crap I've added and changed I've never touched it. ;)
Tstover
141
398
Central PA
I only moved mine to the left a little bit, I guess it would be on the inner fender. That way I didn’t have to make any wiring changes.
NTC/TAP Transition Member
11,886
90,636
Cut up a fallen storm damaged tree, half of it was hanging over the creek so the P500 winch helped out. That wireless remote was so handy pulling out a tangled mess of branches.
Splorin
320
904
Maine
A majority of winch operations should happen outside the rig so you can watch winch and or machine. As a truck/Jeep wincher for years,the first time I used an incab SxS switch :mad:I knew it was going to be the last.
nctrailboss
nctrailboss
440
1,454
north carolina
Yep..I can operate mine from a dash switch,rocker switch mounted at the winch,or by 10ft. remote.
11,886
90,636
My cheap wireless remote kept in the Choobox is still working with original battery 2+ years. The best Accessory for under $20. Range is more than cable length. Wish I had a wireless remote back in 1980s with the FJ40 and 8000lb Warn winch. Think I paid $400 back then, and the new version is now $2k. One BA winch.
757854B2 5917 4688 B66B 141315F7CF4F 68BDBEBC C299 45F9 A6F0 403545319F19 FE6DF6CF 1E48 4C06 BFD9 B9C2DF6A6BCF
Splorin
320
904
Maine
View attachment 175396 View attachment 175397 View attachment 175398
Sold several Jeeps after the Cruiser and I keep my 8274 everytime. Paid $200 35 years ago. Mounts were cheap until new JK ($400:eek:). Youngin's do scratch their heads starin at it....
nctrailboss
nctrailboss
440
1,454
north carolina
What year is that FJ?.I had a 71,72,and a 74 with the 350 Chevy conversion.In my opinion,the 6's were better.My 71 was like your light blue one.If I remember correctly,my 71 was 3 speed on the tree.
