Talon What paddles on stock rims
Jay316
I plan on getting paddles put on the stock rims but recommendations you guys got since the front rim is pretty narrow. Thanks
I just picked my Talon yesterday, yay me. While looking stuff over, I recall Rocky Mountain having Tusk paddles that go in a 15” rim. I have no idea how good they are. I usually ran ITP on my Raptor.
Jefferson87
Jefferson87
258
275
Northern California
  1. Talon X4
BPINE
BPINE
73
90
San Jose, Ca
www.youtube.com
I wanted to use my stock wheels as well but am a bit concerned about the tire coming off with low pressure but sure hate to spend more money on bead locks if not necessary.
Jefferson87
Jefferson87
258
275
Northern California
  1. Talon X4
I'm not a sand guy, but how low are you talking? I've been running 32 carnivores in the snow at 2 lbs or even a little lower with no issues. I'm not going slow either.
Reactions: BPINE
BPINE
BPINE
73
90
San Jose, Ca
www.youtube.com
That sounds encouraging, Sand tire sidewalls are very soft I am not sure if that will make a difference.
Jefferson87
Jefferson87
258
275
Northern California
  1. Talon X4
That's what I was thinking also.
Another redneck trick I've used with big tires on a crawler in the snow is duct tape. Just wrap it around the wheel over the bead area. 2-3 wraps is all it takes, and it just tightens the seating of the tire. Only really needed for tires that don't seat tightly on the wheel.
Mforrest
  1. Talon X4
Got them mounted but won’t be able to test until next year
How did the 32” do? I would like to go with the ss360 as well but am afraid of too much power loss with the 32’s
Junkyard
29
52
San diego
I recently got a talon and put ss360 sand tires. Got the 30’s and different width wheels, just followed what chapperel motor sports sells as a set. Got a ok deal with Black Friday and easy to mount on beadlocks.
mines an x4, i did find one sand hill I couldn’t go up but not many. I tried more air pressure this time and got wheel hop so I’ll go back down. 10psi front and 12 back was too much, which I assumed but tried anyway. At the same psi the tire diameters where off by an inch.
I found that it could bog going up hills so I’m glad I went with the 30’s.
ive only had sand rails before and not in 15 years. Quite a different experience.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
I have some similar type tires (but 28") and have been running them for 2 seasons. I have found the following...
  • 6 PSI rear and 5 PSI front works the best for me. I have an R with some extras and weigh in at 1850 lbs. A near stock X4 will be about the same weight. If you have a lot of additions or carry 4 people, adjust your air pressure accordingly.
  • I almost exclusively use i4WD at the sand dunes. Not only for traction, but for handling and safety. The machine maneuvers better. I once tipped my machine because it was (mistakenly) in 2WD and when I tried to power out, it failed to pull the right front tire out of a ditch it was in and caused the rear to slide sideways and laid me on my side. Had I been in i4WD, it would have pulled me out of the predicament I was in.
  • Auto and Sport mode work fine as long as you are not climbing any hills. The DCT programming does not understand sand and attempts to keep the wheels from spinning and will shift you up out of the power band. For hills, put it in manual and keep the wheels spinning slightly and the RPM at 6500 to 8500 until you crest the hill.
Reactions: BPINE
Mforrest
  1. Talon X4
What other type do you have? I didn’t know there were others out there. ( besides true paddles)
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
QuadBoss makes some. They are OK. I recommend them if you have a lot of rocks and other non sand surfaces at your dunes or are new at dunes because they are pretty tough. They hold up better than Scats under those types of conditions.
If you have good dunes or are experienced enough to avoid the crap, then get yourself some Skats. A couple in our group run 30" Skats. I keep up with them until we get to the hills. Now that I have some experience, I will get some Skats this spring. They now make a tire appropriately called "The Talon" :)
Reactions: Mforrest
Junkyard
29
52
San diego
thanks for the advice, I’m mostly taking my kids around so Im more safety oriented these days.
I’m going to try the manual hill climbing over the next couple days.
