Does anyone have any suggestions for removing white lithium grease from the black textured plastic? Tried lubing the door bushings with it, and it did NOT come off. It's been thru about 12 power washes, and tried wax n grease remover.
Maybe brake cleaner?Does anyone have any suggestions for removing white lithium grease from the black textured plastic? Tried lubing the door bushings with it, and it did NOT come off. It's been thru about 12 power washes, and tried wax n grease remover.
☝️ ☝️ ☝️☝️THIS☝️☝️☝️☝️Or the old school approach: WD-40 or gasoline
oil based (WD40) then wash clean with dish detergent☝️ ☝️ ☝️☝️THIS☝️☝️☝️☝️
Goo Gone didnt work, Wax n grease remover worked OK with a tooth brush (which is basically the same thing as goo gone, but I didnt use a toothbrush with it so it may have worked similarly), but you can still kinda see a white haze. but havent tried the WD-40 yet. Did it work @Hondasxs ?☝️ ☝️ ☝️☝️THIS☝️☝️☝️☝️
In post #9 second pic looks like it didGoo Gone didnt work, Wax n grease remover worked OK with a tooth brush (which is basically the same thing as goo gone, but I didnt use a toothbrush with it so it may have worked similarly), but you can still kinda see a white haze. but havent tried the WD-40 yet. Did it work @Hondasxs ?
Try mr. Clean magic eraser pad.In post #9 second pic looks like it did
😱 Smitty!!!!!!!!!!!!! You have a twin?!?!?!? 😂😂😂Try mr. Clean magic eraser pad.
Well after all that, you might not use so much grease?Goo Gone didnt work, Wax n grease remover worked OK with a tooth brush (which is basically the same thing as goo gone, but I didnt use a toothbrush with it so it may have worked similarly), but you can still kinda see a white haze. but havent tried the WD-40 yet. Did it work @Hondasxs ?
No buggy to show yet. Still trying to decide what I want.😱 Smitty!!!!!!!!!!!!! You have a twin?!?!?!? 😂😂😂
🤔 first post......welcome to the forum from south Fl
I'm sure someone will be along very shortly to enlighten you on our most prominent rule around here 😉 👍
Have you considered a KRX ......... I hear the RMAX is all the rage now a days......😂😂No buggy to show yet. Still trying to decide what I want.
Dont know why this has anything to do with this thread? but….Dear @Remington, please post a picture of your bad self right after you plopped out into this world and before the Dr. smacked your butt . . . or, as we all know, it didn't happen!
