P1000 White lith grease nightmare
cornbiscuits
cornbiscuits
12
40
Warrenton, Mo
Does anyone have any suggestions for removing white lithium grease from the black textured plastic? Tried lubing the door bushings with it, and it did NOT come off. It's been thru about 12 power washes, and tried wax n grease remover.
Hondoman
Hondoman
727
1,697
Texas
Maybe brake cleaner?
63,964
I have the same issue. This is 2 pressure washings in.
So let's give it a test.
It works.
24513a481d67d3123baf09c8235d49d2.
577b45df1fbe628acb9dbdfa86c24a28
cornbiscuits
cornbiscuits
12
40
Warrenton, Mo
☝️ ☝️ ☝️☝️THIS☝️☝️☝️☝️
Goo Gone didnt work, Wax n grease remover worked OK with a tooth brush (which is basically the same thing as goo gone, but I didnt use a toothbrush with it so it may have worked similarly), but you can still kinda see a white haze. but havent tried the WD-40 yet. Did it work @Hondasxs ?
107,287
In post #9 second pic looks like it did
JenElio
JenElio
65,015
608,582
Loxahatchee, florida
Try mr. Clean magic eraser pad.
😱 Smitty!!!!!!!!!!!!! You have a twin?!?!?!? 😂😂😂
🤔 first post......welcome to the forum from south Fl
I'm sure someone will be along very shortly to enlighten you on our most prominent rule around here 😉 👍
207,989
Well after all that, you might not use so much grease?
107,287
Dear @Remington, please post a picture of your bad self right after you plopped out into this world and before the Dr. smacked your butt . . . or, as we all know, it didn't happen! :)
Dont know why this has anything to do with this thread? but….
heeeeere you go!!!!
2508A690 38B4 4608 B6E8 DDD1DEE2D26C
