Thanks for the link. Some good stuff in there. I'm thinking I'll stick with 6 ga. wire. Hopefully today will search around a little for a spot for the circuit breaker near the battery.
Didn’t know that....Also there is a pre-traced cutout on the backside of the dash for toggle switches.
I used 4g and have never had trouble...Ok, decided to go with 4 gauge. Figured this is a good place for a spot of overkill.
Will try to use the supplied cables for the short run from breaker to battery. I believe they are 6 ga.
If doing that, keep in mind the breaker amp rating should not exceed the rating of the supplied cables.Ok, decided to go with 4 gauge. Figured this is a good place for a spot of overkill.
Looks good.I have heard good things about koi winches.How do you like the bear claw tires?
