harrelljr99
harrelljr99
74
122
You are correct. HL a arms and 2.5" HL. No spacer. 14" rims 30" tires
Reactions: Eltobgi
BIGRACK
BIGRACK
202
376
Dayton Tenn
Windrock will the fox shocks work with stock wheels and tires with a HL lift .I have the arched arms on rear installed a arms backordered for front. Plan on ordering shocks tomorrow. Just want to know what to plan on having to do. Also will they work with lift off. Thanks in advance for your help.
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
The shocks will work with the lift off. My problem is my wheel setup. 5+2 offset. 10" wide tires on 7" rims. The HL lift is causing me all kinds of problems with the shock clearance. I think the front clearance is going to get worse when addition of the Superatv front arched arms (when they come in) because everything moves forward but the shock. I am going to swap to factory tires and wheels in the morning. I will keep everyone posted.
Well I'll buy those old junky ass shocks off ya!!
Eltobgi
Eltobgi
4,599
15,187
North Dakota
@harrelljr99 can you do a similar test with your set up similar to @Windrock1000 fully compressing front shocks to see if contact is made between shock and tire?o_O I do understand that you have larger tires and HL Front A Arms & HL Front 2.5 lift & 30 tires not sure on your rim offset
harrelljr99
harrelljr99
74
122
I have 14" kore m20 rims. How did he fully compress the shocks?
Reactions: Windrock1000
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Looks like your rims are 3.5 x 3.5, so a 0 offset! That explains why you were able to mount your rear shock with the reservoir out! It looks like in the picture he has his shocks set to the softest setting and parked at a downward angle with front tire compressing the shock because of the hill! @Windrock1000 ?
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Does anyone know the stock clearance in the front and rear. Pulled the High Lifter and put factory tires back on. Need to set the preload on the Fox Shocks.
Reactions: CumminsPusher
harrelljr99
harrelljr99
74
122
I think the factory specs claim 12" ground clearance, they don't specify for front or rear or if they are different?
Does anyone know the stock clearance in the front and rear. Pulled the High Lifter and put factory trips back on. Need to set the preload on the Fox Shocks.
12.4 is Honda claim. Not sure where that's picked up at.
@windrock did you by any chance measure the sag?
With factory setup and new rear arms the sag is 4.75"
How much of that do you think could comfortably become lift with spring load?
