@Windrock1000 , if you are going to remove the lift maybe you can give us performance comparison with and without?![]()
Windrock will the fox shocks work with stock wheels and tires with a HL lift .I have the arched arms on rear installed a arms backordered for front. Plan on ordering shocks tomorrow. Just want to know what to plan on having to do. Also will they work with lift off. Thanks in advance for your help.
Well I'll buy those old junky ass shocks off ya!!The shocks will work with the lift off. My problem is my wheel setup. 5+2 offset. 10" wide tires on 7" rims. The HL lift is causing me all kinds of problems with the shock clearance. I think the front clearance is going to get worse when addition of the Superatv front arched arms (when they come in) because everything moves forward but the shock. I am going to swap to factory tires and wheels in the morning. I will keep everyone posted.
See.. I'm a problem solver!
@harrelljr99 can you do a similar test with your set up similar to @Windrock1000 fully compressing front shocks to see if contact is made between shock and tire?I do understand that you have larger tires and HL Front A Arms & HL Front 2.5 lift & 30 tires not sure on your rim offset
Thank you sir. Setting at 11.25" right now. She looks sick.I think the factory specs claim 12" ground clearance, they don't specify for front or rear or if they are different?
12.4 is Honda claim. Not sure where that's picked up at.Does anyone know the stock clearance in the front and rear. Pulled the High Lifter and put factory trips back on. Need to set the preload on the Fox Shocks.
Thanks CP. These A Arms are a b**** to adjust. Of course when you pull the lift the camber goes out the window. I cant get close the caster they state. +3-4 degrees. Still working.12.4 is Honda claim. Not sure where that's picked up at.
With factory setup and new rear arms the sag is 4.75"@windrock did you by any chance measure the sag?
