Windrock1000 submitted a new Garage Item:
Windrock 1000's- She's Foxy Now
Man it's soft right now. I'm going to bring it back up to factory clearance and we will see. Normally you should want half the shock travel for sag. Correct?How much of that do you think could comfortably become lift with spring load?
I'm not sure the exact number I always went by feel on bikes but yes good amount. You want down the stroke a little bit but I figured with all the weight we have on these things they'd be soft, without the lift so I guess I was wondering how much we could add without thelift to try to meet in the middle. I'm not wanting to lose much left but if the rig did perform better and not much height was lost I'd be down. Mine really rides well but it's fun to screw with things so kind of curious what your end numbers are that'll probably help my decisionMan it's soft right now. I'm going to bring it back up to factory clearance and we will see. Normally you should want half the shock travel for sag. Correct?
Yes it wil clear with factory wheels and tiresWindrock will the fox shocks work with stock wheels and tires with a HL lift .I have the arched arms on rear installed a arms backordered for front. Plan on ordering shocks tomorrow. Just want to know what to plan on having to do. Also will they work with lift off. Thanks in advance for your help.
@harrelljr99 can you do a similar test with your set up similar to @Windrock1000 fully compressing front shocks to see if contact is made between shock and tire? I do understand that you have larger tires and HL Front A Arms & HL Front 2.5 lift & 30 tires not sure on your rim offset
Good info! And thanks go to @Windrock1000 for his testing and discovery! We are all learning together!Thanks for probing the question. After looking at it when I got home today I'll have to flip the adjusters to the inside. The front would be close to contacting the piggyback adjuster and would definitely if the wheel was turned at full compression. The rear upper a arm will hit the piggyback adjuster fully compressed as it is only about 4.5" from touching it now. I'll flip them to the inside.
The shocks will work with the lift off. My problem is my wheel setup. 5+2 offset. 10" wide tires on 7" rims. The HL lift is causing me all kinds of problems with the shock clearance. I think the front clearance is going to get worse when addition of the Superatv front arched arms (when they come in) because everything moves forward but the shock. I am going to swap to factory tires and wheels in the morning. I will keep everyone posted.[/
Thanks Windrock for info on this . Your doing a fine job there.Yes it wil clear with factory wheels and tires
1" spacers added to the front...
2" spacers added to the rear...
Problem solved!
The numbers have changed to .880 and 1.024". For High LifterView attachment 37239 View attachment 37238 View attachment 37237 This will get you really close with High Lifter bracket in place.
I think the factory specs claim 12" ground clearance, they don't specify for front or rear or if they are different?
what GPS is that?Fox Test Ride Video
Garmin VIRB Ultra 30 camwhat GPS is that?
Update on Fox Shocks and High Lifter. I have a High Lifter Bracket Lift for sale! I removed the lift and added preload to the Fox Shocks. No sway bar.
All measurements are from the top of the treads to the top of the adjustment ring. (not the lock ring)
LF- 2 5/8"
RF- 2 1/8"
LR- 1 1/2"
RR- 1"
Shooting for 33% droop. Have 14" of frame clearance Front and Rear on stock tires at 14#'s. Very Happy. It has the firmness of the High Lifter Kit but the travel of the Foxs. I will be about 1/2" lower with my 28" Roctanes than when I had the High Lifter Installed. @CumminsPusher
1/2 is all. Damn I'm listening lol. So that means about inch of drop for me. You ran both ways and you're that much happier without the lift and springs tighter? Springs are setup for driver only correct?
Sent from my iPhone using Tapatalk[/QUOTE
Yes the extra 1/2" is for driver weight. I do like it better. It feels a lot different because of the missing sway bar. I'm going to the mountains this weekend for a true test. It has passed the yard test.
It's strange but 1" of adjust gives you a little over 1" lift. 1:1.1 or 1:1.2
That thing looks mean! Are those 29" tires? Let me know how you like the shocks. I was thinking about doing the HL arms with no lift and running 30's.
