P1000 10,000 mile report, Nothing Broke
hondabob
1,161
4,537
Prescott Valley, AZ
Just got 10,062 miles and 518 hours on it and no problems. Just oil changes and tires. I'm getting the clutch oil mod upgrade next year and hope to get 20,000 on it next year. I installed the Fox Shocks and a Teryx bucket seat back for my 7 hour rides.
20171211 133344 resized
20171211 133414 resized
Trapper5885
North Idaho
Wow, that’s awesome and very encouraging for those of us with just a few hundred mile on ours , relatively new at this SxS thing . Not to be to noisy,but what is it that you do to get so many miles on , besides ride?
tig
tig
116
176
That's awesome. Got some pictures of your seat setup?
E
elkguide
3,377
7,963
Vermont
AWESOME!!!!!!!
Now we all have a goal to shoot for.
265,449
Thanks for the update @hondabob. Glad it is serving you well.
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
Do you have photos of the seats and mounts?
Hawk53
Hawk53
461
587
Alberta Canada
View attachment 59745 View attachment 59746
Wow that is awesome. You must do mostly dry running. I would expect at least a wheel bearing failure going by my Quad usage.
hondabob
1,161
4,537
Prescott Valley, AZ
I cut the bottom off the Teryx seat frame so it mounts with 4 bolts. The stock seat back needs to be opened up to remove the foam. I use an electric knife to trim out the foam then glue it back and staple the edges. This mod moves the seat forward about 1 1/2 inches and may not be good for a 6 foot plus driver. This bucket seat back makes a 7 hour ride comfortable. The Fox Shocks help too. I put 11,931 miles on my 2016 Yamaha YXZ or I would have 22,000 on it. With good maintenance we should get 60,000 miles before we need any repairs. Low speed rocks and water will be less. My speed average was 19.4 and I did about 5 % rock crawling with the front locker on.
20171213 205812 resized
20171213 205903 resized
20171213 205923 resized
20171213 205939 resized
20171213 210007 resized
Lockedsteering
Reactions: Mudwing and tig
cwalton
cwalton
Who has more fun!
334
724
West Virginia
Sounds great, keep us informed on how it does as the miles keep clicking along.
hondabob
1,161
4,537
Prescott Valley, AZ
I run 8 to 11 PSI. My front tires have about 9,000 miles on them. I cut a side wall so replaced the rear tires. My 2016 Yamaha YXZ got 9,800 miles before I replaced the tires.
Mikee
24
12
Washington, NC
Man, that's great! I like hearing good news every now & then about the Pioneer. BTW, what about the 3 B's (as I call it?) Bearings, brakes & bushings. Have you had to replace any these yet?
Reactions: Someguy
hondabob
1,161
4,537
Prescott Valley, AZ
Only had to replace bearings, ball joints, U-joints, and bushings on my Polaris models and I don't run in deep water. Had to replace the parking brake pads on my Yamaha YXZ at 11,000 and some miles. My brakes are still like new but some of the mud guys had had to replace them. I think the A-arms are rubberized and last the life of the vehicle. They must be installed per the shop manual so they are centered. Wheel bearings may wear out if run in water all the time or with a large wheel offset like a 4-3 wheel. I run 5-2's which will be a littler harder on the wheel bearings. For what these UTV's cost its inexcusable to have poor quality parts. Honda and Kawasaki are the best with high quality parts but anything can have a flaw and fail.
Reactions: elkguide
walexa07
walexa07
396
380
Louisiana
Can you clarify what you've had to replace on the Honda Pioneer? It sort of sounds like nothing at the point of this thread but just wanted to be clear.
Thanks,
Waylan
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Just got 10,062 miles and 518 hours on it and no problems. Just oil changes and tires. I'm getting the clutch oil mod upgrade next year and hope to get 20,000 on it next year. I installed the Fox Shocks and a Teryx bucket seat back for my 7 hour rides. View attachment 59745 View attachment 59746
Might consider sending the same note to Honda directly. Who knows how positively they may respond....
hondabob
1,161
4,537
Prescott Valley, AZ
Over 12,000 now and had to replace the shift cable and one exhaust rubber mount. Parts are under $35.00 so far. It looks like the sport models will use a version of this engine package so I expect They will be very reliable too. Like most on the forum I'm getting tired of waiting although I didn't wait. I bought the 2016 Yamaha YXZ even though I knew it had a lot of problems that needed to be fixed. Got over 13,000 on it now.
Reactions: alloutdoors
