2018 PIONEER TAKEOVER - April 20 & 21 - Ride Royal Blue!
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I've got 3 ram mounts along the rops - one on drivers side for me, one on the passenger handle for the wife, and one along the top for an old phone used for gps and the vibration is very minimal. My wife did some recording at Mulberry and it turned out pretty good with only a tiny bit of vibrating if we were stopped or just barely moving. I've been curious if the weight of a tablet would increase it much, so looking forward to hearing your results.
I Saw the set up for your wife's phone and thought that would be great for video on the phone. I actually meant to ask what ROPS mount you were using.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
When I put my tablet in mine I could rotate the device.. NOT where the ball clamps but where the slack of the x grip arms go back into that little spring mechanism. It would rotate 70* clock or counter clockwise from centered.
Yea that bugs me too
Reactions: BWAF and JTW
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
The new holder is made for a Samsung Tab a with an otter box. This should take care of it.
You can put your device in my clamp and see if you like it. I dont recall much rotation with my ipad, or not enough to bother me.
Reactions: JTW
66c841732b6e20505d6e06cb5011295b
Mine shook too much and I couldn’t read it so I welded a mount that clamps to the ROPS.
nbomar
nbomar
4,416
17,855
Springdale, AR
I am going trying a ram claw mount to the side ROPS - extending the tablet out in front of me - hopefully mounting to the ROPS will cut down on the vibration... the ram mount on my switch plate vibrates like crazy with the phone so I hardly even use anymore...
I have this setup already. I’ll let you know soon.
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
Here are the balls I mounted to center ROPS.
7EE4CC45 1BB5 4DFA AECA 2BA27F048CD0
70D86BC4 9459 488E 859F DCB712CD0CFC
Reactions: markie
So i had a difficult time finding a case I liked for my tablet.. very few waterproof options! I ended up ordering some clear vinyl material, hot gluing the openings and gorilla taping he holes on the device. This is an otter box defender. The back opening where he camera is.. I cut a piece of plastic and hot glued it inside the case. Should be fairly water resistant and dust tight. If anyone needs some of the adhesive backed vinyl material I put on the screen protector holes I’ve got a 12”x12’ roll.
3920A023 CC70 4AA4 873C 3923F77DA9A4 D05FDAEC D1C1 4CEF 83CE EF1182DC3F51 378DB21B 7834 40AD A9B3 6FB87AF553C0 B55D375B 60E5 4785 B3E7 02FF97CB12DD E2D4D5AC 0329 4617 B1F5 1396418E9AD4
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I know it's been covered.
What app is best for maps. Can someone point me in the direction of that discussion....
Reactions: BWAF
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Sorry I have run the set up on the flats of Rush springs just have not given it a good go on a rough all day trail ride. Additionally My ram suction cup worked as well but prefer the clamp and don’t totally trust the suction cup.
68,280
If you want simple... Maplets is the app for positioning but it will not track you.
I recommend maplets for pretty much anyone new or beginning. you can pretty much explore the whole park on your own!
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
View attachment 71586 View attachment 71587 View attachment 71588 View attachment 71589 View attachment 71590
You can tell you ride with @Kilo427 a lot
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
Lot of guys just went to lifetime maps. I think that's what it was I just found an Android app called custom maps if you have the printed map that is scale for where you want to ride of all the trails like Rush springs you take it as a screenshot or picture of and overlay it into their app using two points to a line It and then it's supposed to show you where you're at on that map but it doesn't track you as far as where you've been. I haven't got a chance to try it out but works off line might next week end a rush .
Reactions: JTW and Cuoutdoors
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Polaris ride command app tracks you pretty good at RRB, if you want to dirty your devise with a PO-PO app
Reactions: BWAF
BWAF
BWAF
8,869
42,496
Carthage MO
Another one I want to try is the UTV trails you download the map online and then it's there for offline use as far as Google map Go's and it tracks you here's a screenshot of the two iconsD8bf018594052fff0895f9dcbef2966e
BrophyCreek
BrophyCreek
522
3,250
New Richmond, WI
29" what width? When I was running 28" Motoclaws on 3.5 offset wheel I could rub if I was at full compression turning. now that hardly ever happened so I was not concerned about it. 29" I would expect some rubbing if true 29". By spacer @Cuoutdoors may be speaking of a shock spacer not a wheel spacer. What's the offset of the wheels you are getting or using?
Right now, I have stock wheels. I was going to look into changing the offset to move them out am inch. As far as width, I was going to stay stock but I haven't looked at my tires/wheels to see what stock is....maybe Go slightly narrows if I widen the stance. I have a 16 deluxe so it has the alum wheels.
Reactions: BWAF
BWAF
BWAF
8,869
42,496
Carthage MO
Pretty sure they're a 5-2 offset
Reactions: RB3offroad
