2018 PIONEER TAKEOVER - April 20 & 21 - Ride Royal Blue!
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
You MIGHT get a 28.5” tire with no Forward arched a-arms. Spacers won’t really help fit larger tires they will still rub at lock under compression. Forward offset arms are required for a true 30”
Going to find out when I get my rims in 3 weeks these measure 28.5 38f7973c01f044ecbe8723396c29570c
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
That was my next question, can I go to 29's with stock suspension and not have any rubbing when turning? You answered that, so thank you. What if I do offset out an inch, will they clear then? Same question, what if I only go to 28's
29" what width? When I was running 28" Motoclaws on 3.5 offset wheel I could rub if I was at full compression turning. now that hardly ever happened so I was not concerned about it. 29" I would expect some rubbing if true 29". By spacer @Cuoutdoors may be speaking of a shock spacer not a wheel spacer. What's the offset of the wheels you are getting or using?
Reactions: BWAF
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
View attachment 71571 View attachment 71572 I have a feeling these lifetime trail maps are going to be very handy next week.
with all these radios and electronic maps people are going to be fighting to lead groups :D.... Heck it is fight now to fix your own machine if something happens to it...
Nice set up by the way - like where the ram mount is placed - how does that work for vibration of the tablet
sharp
sharp
3,757
14,955
Tennessee
It has quite a bit of vibration but you can still see the screen. Unless it is fixed mounted on a solid part it's going to vibrate some.
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
I have a piece of ram track mounted in the same spot. Using my phone it vibrates a bit, using my ipad mini it shakes like Micheal J fox. Might have something to do with the weight. I have a couple other pieces mounted on the track as well.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I am going trying a ram claw mount to the side ROPS - extending the tablet out in front of me - hopefully mounting to the ROPS will cut down on the vibration... the ram mount on my switch plate vibrates like crazy with the phone so I hardly even use anymore...
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
I will bring a few spare ram tracks.
I had my garmin mounted on the windshied lock, it shakes the entire time, but the gyro in the camera overcame it.
Edit, I found the shorter the arm the better.
DB6A2B23 C3BA 4AA5 A540 C3802D2EE055
Img 20170820 125703
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
I don’t recall my x mount rotating.
Reactions: BWAF
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
When I put my tablet in mine I could rotate the device.. NOT where the ball clamps but where the slack of the x grip arms go back into that little spring mechanism. It would rotate 70* clock or counter clockwise from centered.
My phone will do the.same thing in mine
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
I've got 3 ram mounts along the rops - one on drivers side for me, one on the passenger handle for the wife, and one along the top for an old phone used for gps and the vibration is very minimal. My wife did some recording at Mulberry and it turned out pretty good with only a tiny bit of vibrating if we were stopped or just barely moving. I've been curious if the weight of a tablet would increase it much, so looking forward to hearing your results.
Neohio
Neohio
Beast of the East
21,743
93,150
Painesville Ohio
Just messed with mine. I found the degree of free rotation is related to how much you spread the mount to hold your device.
Could try the next size smaller x grip to reduce free rotation.
