P1000m5 4 lock
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
so the consensus is a faulty (shift ? ) sensor.anyone know if they have one for each diff and are they interchangeable? it might be easier and cheaper for me to locate and swap the faulty one myself rather than drag across the country
Are you pulling the parts cannon to say it is a shift sensor?
Do you have access to a manual to properly diagnose the sensor?
62,510
Is the lever easy to move between the modes? I know another member had a similar issue a while back and it was because he pinched the cable when installing some accessories up front, but his mode lever was extremely hard to move into diff lock.
aauman88
aauman88
1,091
2,846
that was me :( pinched 4wd cable going to front diff with U bolts where winch mounts. But he says his functions are working just not the indicators.
rickoshea
I know, my buddy had same mount and did same thing so made me feel a little better
nope.moves as it always has.drive shift was always a little stiff but the diff lock lever moves smooth.
Reactions: aprils_fool
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
The only sensor I am seeing in the rear diff is the VS sensor. If that wasn't working, it wouldn't shift properly.
68,247
There is another sensor for lock indication.
I havent had time to look yet.
Reactions: Russ989
Kilo427
Kilo427
1,543
6,441
Look at sensor 3 and bracket 38 just for giggles
And 3, 4 and 26 on the rear second picture
0485A055 15DB 4CFA 8251 20A7DBA4264E 4AE38E5E 30DB 41CF 9594 37FBF1C7ECA8
rickoshea
View attachment 163694 View attachment 163699
i was hoping it was going to be a simple fix.its not looking like it.i have 3 weeks to get it fixed and put my camso tracks on before my knee replacement,then i'm laid up for a few months, and i want it in good working order when i'm ready to get back in it.hopefully before the snow melts and the lake ices off. i guess i'm heading up to the cottage this weekend and taking it into the dealer and let them sort it out..thanks all for the help.
Kilo427
Kilo427
1,543
6,441
Keep us updated I would be curious to know what caused the malfunction for future knowledge!
Reactions: JTW
rickoshea
well,dealer can't get me in for a couple weeks.snowmachine season is here so that's eaten up all the shops time in the area,snow is on the way this week.i'm putting on the tracks today and putting the repair on the wait list.i can still run it the way it is.don't want to but i guess i have to. new update. i went out to the shop to run the p1k up to operating temp before i went in for lunch.stupid thing is working.it hasn't moved since last time i tried to get it working,but it's reading all the locks on the dash..i guess i'm better than i thought.going to actually drive it around and see if it continues to work right after lunch,then the tracks go on.strange,but i'll take it.
Russ989
Russ989
22,645
147,291
Figure out what you did, I’m having the same problem except mine is only showing turf mode.
rickoshea
it's going to take a while before i do.it currently has a mind of its own.saturday it worked fine,sunday it didn't.didn't check it monday before i left for a couple weeks.it's going into the shop,i just don't know when.maybe some time in early spring.
Reactions: Mudwing and Russ989
Russ989
Russ989
22,645
147,291
What sensor is it? I’m having the same issue.
Russ989
Russ989
22,645
147,291
The problem is all contained in the shift box, after adjusting it again, it seems to be working now. Thanks @0860silverado and @HondaTech.
7F6077BB EAA8 4D33 84DC 7F5E9F0ACEBE
EF568134 FBC5 4886 A765 5AED27275538
0714EAE5 A9BF 4A89 84DC DAB483E77B18
