P1000m5 Adam490's Short Bus
56,733
Going through the buggy after our trip last weekend. First up was to pull the skids and I had 3 bolts break off. Should be pretty easy to get out since there is still thread showing. Figured there'd be more since they've taken a beating since the last time I pulled the skids off. Crossmembers all look good but my side rails have taken a severe beating. I'll have to replace them and reinforce with angle iron soon. I've got a little slack in the steering somewhere that I'm still chasing. Think it might be slop in the rack bushing since everything else seems to be tight.
56,733
Should have done this from the get go....
IMG 20200604 165203
IMG 20200604 165310
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I'm running 2.5" ID in rear on Fox QS3
You must have gotten rid of all the plastic and put some different end caps on? The fox shocks come with a 3” rear diameter spring ... i was first going to try some spring of Joeys that were 2.5 and they did not quite work. @GlockMeister
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Here is a link to the stats for the fox shocks for the 100o-3 and 1000-5
TripleB
TripleB
11,731
99,682
Caryville, Tennessee
How did those caps for the reservoirs work out for u? The fronts are pissing me off how they pop when they extend down into a hole. I was kinda of waiting to see if those fixed that problem before I ordered.
56,733
Yep, I got rid of all the plastic. The little boots just held mud in there.
IMG 20200218 205822
56,733
I've got about 350 miles on these now in some pretty gnarly stuff and have no complaints. Only time it bit me in the ass is when a stick or something jammed into the retainer and a rock magically wedged itself between the retainer and the shock end. Had the spring tweaked and it rubbed the shock body. I don't think having the plastic would have done anything to help it in that case either, but I can't say for sure.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
there is a plastic piece that you can get that will fit the the 2.5 better on a shock that take a 3.0 but I can’t remember the name of it ... it is like a collar spacer - helps to keep the spring off the body of the shock ..
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Adding the caps and really getting the shocks charged up made a huge difference .. I think it was the leaked gas that started me looking to make suspension adjustments.. A easy way to tell if your shocks need to be recharged is by simply turning the dial from soft to firm...if you can feel a good indent as you change you are probably alright.. when I took mine in I could almost make the rotation with one finger on the dial. There was nothing to stop the dial at each location - if that makes sense
TripleB
TripleB
11,731
99,682
10-4. I'm pretty sure mine has lost its charge.
Reactions: Ridinfool
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
I hated those rear shock plastic covers. Broke 4 of them on my 2 sets of Fox shocks. Taking them off was a good idea
Reactions: Adam490
56,733
If you're referring to the spring retainer as the end cap, the stock springs have a plastic spacer that accounts for the slight overhang. 2.5" ID springs fit perfectly on the spring retainer without all the plastic pieces.
Reactions: Isaiah
56,733
Figured out where my slack was when I pulled the wheels to change brake pads. Damned driver upper SATV arm. Anybody ever figure out how the hell to prevent this from loosening or should I just check it every ride??
Russ989
Russ989
22,569
146,535
Lock tight, I had the same problem.
Hondoman
Hondoman
727
1,697
Texas
rears are 3” diameter
Front are 2.5” diameter
at least on the foxes
Wasnt there an older version of the fox rear shock that took the 2.5" spring?
Mine are newer and were 3".
