highpocket74
Did I read you sell these? Do they make them for a P-1, I need one.R2C cleaning instructions provided with every filter shipped.
Thanks for the pic. 👍Still running stock intake. So the dirty side was of course dirty.
Pic below taken after ridden on 50 miles of national forest trails this month. Air box and filter were cleaned prior to this ride.
The point I'd like to make is that these are main air filter elements that work well, not precleaners. That is why I shared the clean side of the airbox with you guys. You can add precleaners to extend maintenance intervals and filter life.
Will modifying an intake cancel out your warranty?No intake noise and I'm at 4,000 miles now. Looks like I will replace the pre filter at 6,000 to 7,000 miles. I don't follow in the dust and since the prefilter is in clean air it stays fairly clean. I sold my Pioneer 500 to my buddy and with the under roof prefilter the stock air filter is still clean at 8,000 miles. He cleans and reoils the prefilter every 1,000 miles and rides in mild dust occasionally.
That’s great news! Should have mine today....👍Using my r2c filter I added a bit of extra caution with out any noticeable power loss. I bought a piece of the green filter foam that UNI sells in a package, my Honda stealership has it in stock. I cut a piece to cover the intake tube (s) and held it in place with a wire tie wrapped around the outer edge. I oiled the foam with uni foam oil so as to catch any debri that happens to get past the r2c filter. To date I have about 250 miles on dusty country gravel roads and I not found any dirt or dust particles on the uni filter foam. I keep a close eye on the foam and so far so good. The r2c filter is the way to go if a snorkel system or particle separator is not used.
I have a 70 mile poker run on the 25 and if there is no rain the ride will be a dusty event, I hope it is so I can put the filter to the test and report back.That’s great news! Should have mine today....👍
Short version - drill the hole.Lots of good info on this write up and the one Fartsalot did on the R2C. Thanks for all the info and pictures.
So just thinking out loud, for those of you who have taken the inner fender off and snorkel kit, would it be possible to cut and add the UNI filter inside that inner fender thus reducing the need to cut a hole? How hard is it to remove that fender? Harder than taking storage box out, taking stock filter out, and then taking the UNI filter off inside the air box, assuming you added one? Fartsalot advised that the gaps between that fender and the inner wall are wide and dirt just flows through there mad. But are those gaps small enough where you could add adhesive foam tape to the inner wall or fender? Thus trying to get the air draw from the side grate. Once again, I'm just thinking out loud to try and find a way to filter the air coming in and not cut a hole, and or go under the stock filter. I may be way off base.
Please let me know your thoughts.
Thanks!
They make a fabric cover that's supposed to allow airflow but reject water for exposed pod filters. BUT - they also made similar 2" button inserts for snowmobile airboxes that were supposed to stop snow infiltration - the problem was they didn't flow anywhere near as much air as advertised, so I'm a bit gun shy about the idea. They have a drawstring to hold them on so I wouldn't cinch it down tight, allowing air to flow in from the bottom.CID - thanks for the brutal honesty. Seriously its good to know that removing that panel sucks, and the outside filter is the best way to go. I'm going to look at mounting it just up from the panel and see if I can find a cover, like an up side down 3 quart bucket, to go over it to keep it from getting wet. Obviously it's a pre-filter, so a little wet won't kill it.
Thanks to HondaBob, and the others that chimed in on making this mod.
I don't remember the name of the covers, maybe @Lil_Steve can post up a link. He uses one and seems to be happy with it
but that boy ain't rite.
Does anyone know the part # for that ^
I think it was in @jasond build sheet or YouTube videos. Sorry I’m not in position to search for it now.
