Talon Best Tablet brand/size for GPS (i.e. Gaia) usage
stellarpod
stellarpod
821
3,024
OKC, OK - USA
I am contemplating buying a dedicated tablet, RAM mounted into my Talon 1000X to use for GPS trail duty with software such as Gaia or equivalent. I would be Bluetoothing to my new Galaxy S10 for connectivity, although I'd be open to other alternatives if you've got better ideas (GPS pucks, etc.)
QUESTION: What tablet do you use or prefer for said duty? I'm leaning toward a Samsung product, only because that's the phone brand I'm using. I've used an iPhone most of my mobile life, and have an iPad, but I'm reluctant to spend the dollars Apple wants for their tablets and I'm not wild about constraining myself to Apple's proprietary nature, particularly for this application.
Any and all suggestions will be cheerfully considered and honestly appreciated.
Steve
Dwight
27
Kansas
I started with a 8" tablet and then moved to a 10" Samsung. I'm older and the 10" screen was much easier to see. I used the Gaia app some and then went with the Avenza app. Avenza has links to the MVUM maps that we use plus a ton of other options. Download the area maps you need before you need them and then there's no need to worry about connecting.
Dwight
Vondy
Vondy
1,393
8,873
Houston,OH
Supposedly Samsung has more accurate GPS. I run a 10”. I have Gaia, orux, and some others loaded. I use Orux the most often. No data connectivity required once you have the info loaded you need.
Hondroid
Canada
Steve
I use the Garmin GPSMAP 276CX. Large high res screen and water proof.
Reactions: stellarpod
265,473
Steve
From strictly a hardware standpoint the GPS chips used in the Samsung Galaxy Tab A series seems to be the best overall at accurate tracking outside of a true mapping GPS such as the Garmin Montana 600 series. The only downside to the Garmin is the 4" screen, which is great for portability, but is lacking when trying to read on the fly going down the trails. This is my humble opinion after owning 2 Garmin Montana 650Ts and migrated to the 10" & 8" Samsung Galaxy Tab A tablets originally using the Oruxmaps app for my trail duties.
The particular GPS chips in the Samsung tablets not only tracks US GPS, but also the Russian GLOSNASS satellites offering a bit of redundancy. You need 3 satellites minimum to get position accuracy within 100 feet, these chips track up to 12 satellites concurrently for some of the best non military hardware accuracy available as a true stand alone off road GPS solution especially for under $200.
stellarpod
stellarpod
821
3,024
OKC, OK - USA
Well, that 4" screen would be right at home next to the Talon's puny instrumentation. :D
Steve
stellarpod
stellarpod
821
3,024
OKC, OK - USA
I'm wondering if I should just use my Galaxy S10 phone at first, just to get a handle on usage of the different software (Gaia, Orux, Avenza, etc.) and then move up to a tablet once I've concluded which software I prefer? I've already got RAM mount accessories for it, would just need to mount a ball somewhere.
Steve
265,473
Steve
Here is what Orux maps app looks like on a Samsung Galaxy 8+ phone with a good topo map and Mudcons trail overlay.
Screenshot 20190513 121231 OruxMaps
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
And if some reason the gps is poor on your tablet or you have a none gps version of a tablet this will hook you up to satellites and hook to the tablet Bluetooth. I have used the older 150 version with very good results just testing it.
XGPS160 - SkyPro GPS Receiver
I just recently got a 150 over the 160 mainly due to amazon reviews of the 160’s crapping out and having problems. I’ve got a 10” amazon fire tablet that I’d picked up a while back and the 150 works great with it. I’ve only been able to test it on the sxs around the house, but I put in the truck and ran some errands and went to the liquor store and it was amazingly accurate - I zoomed in and it showed down to the foot how I parked in the lot! I could see how I drove out of the lot dodging potholes and everything... was really cool. Just hope it works the same out on the trails. We may take a ride up at Brock Creek later this week so I’ll get to officially test it out.
Kilo427
Kilo427
1,543
6,439
worked flawlessly on the trails during take over
A
Average_Joe
881
3,001
Gainesville, Fl
  2. Other Brand
red124
15
38
MN
Just wondering why nobody other than me ever mentions using the free polaris ride command app? I have a refurbished samsung galaxy s2 8" wifi only and never had a problem. It has a bunch of trail already loaded on it and you can map or track your own. Only thing you have ot remmeber to do is download the trails for offline use when you are riding in areas without cell service or wifi. I also found that a matte screen protector work fairly well to cut down glare but does get dirty easy.
Reactions: TimG
A
Average_Joe
881
3,001
Gainesville, Fl
  2. Other Brand
I use it but I haven't figured out how to download trails, offline it doesn't track very well. I will tinker with it tonight. I bought the Garmin Glo 2 to help my 8in tablet with better accuracy it picks up quite a few satellites.
I just figured out how to download offline maps I will do that tonight I didn't know it had that ability.
Reactions: TimG
265,473
What is mudcons
What is Mudcons trail overlay? And what is Topo map?
Read this thread, should get you up to speed. Don't understand a term, Google is your friend.
OruxMap's - My GPS Replacement!
Mudcon is a user with several trail systems on overlays that can be used in conjunction with topo and or base maps using Oruxmaps app , check out his YouTube channel
Reactions: Byrdman
I
iloehr99
44
64
Southern Indiana
I just recently got the Samsung Galaxy Tab Active 2
https://www.amazon.com/gp/product/B07856DNSX/?tag=sxsweb24-20
And I use this ram mount holder which plugs in the 12V cigarette lighter and charges when the tablet is put in the holder.
https://www.amazon.com/gp/product/B010E41EA6/?tag=sxsweb24-20
I use the Backcountry navigator Pro. I have used this app for years on my phone and it has worked great. There is a new version call Backcountry Navigator XE which is way better. I haven't got a change to use it on the trails yet but the user interface is much much better.
The tablet is extremely durable and you don't have to worry about it getting wet. I was riding at Rush Offroad in Kentucky and it downpoured and it worked just fine in the rain. It was even still easy to use the touch screen with it wet. I don't have a picture of it mounted but I will try to get one and post it later.
rbtnt
rbtnt
74
55
Are you happy with the Active 2 tablet? I tried Backcountry Navigator XE and it seem to have bugs. I'm looking at getting an Active 2 tablet to load Backcountry Navigator Pro and OruxMap. I tried both on a Galaxy S7, but don't know which one I like better. There are pros and cons for each one.
Did you get a chance to tale a picture of yours mounted? I am looking at getting a locking mount that is easy to unlock and remove.
I
iloehr99
44
64
Southern Indiana
I'm really happy with the Active 2. Mainly that its extremely durable. I don't have to worry about getting mud and water all over. I still try not to get crud on it but it's gonna happen. Also, it's just like using my Galaxy S8 Active phone so it's easy to use for me. I agree on the XE. Hopefully they will get it straightened out soon. I use the Orux when I can't get maps to overlay on backcountry, I can usually get them on the Orux. Here's some pictures I got of my phone mount and the tablet mounted in the Pioneer and in the Talon.
20190614 093230 20190614 093245 20190614 093418 20190614 093434 20190614 093728 20190614 093743 20190614 093812 20190614 093823
