P1000 Big horn 2.0
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
Has anyone had issues with the sidewalls crackin on the stock Big Horn 2.0? What is a good tire for trail and mud?
Reactions: sharp
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
I love my Big Horn 28 inch 2.0's but we don't have big pointy rocks where I ride either.
Same here. This is the second tire that formed cracks on the sidewalls and these tires are not cheap. Checked tire pressure evrytime we ride.
dnjones161
dnjones161
583
1,713
Ohio
Maxxis warrantied a pair of big horns for me on a RZR after they had treads start to separate from the tire roughly 200 miles in.
It's worth putting a call/email into Maxxis IMO.
I've been pretty happy with my tusk trilobites- just a maxxis bighorn knock off. 8ply. I think that trade patterns pretty good for the riding that we do. Somebody that does a ton of hard pack or roads may disagree.
Reactions: Cecilthelion
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
Thanks. I will give that a try for sure.
Worth checking with them for warranty. I’ve ran a lot of BH 2.0’s on multiple machines and never had that happen.
Reactions: TheHoover
322,690
Being around snow and mud so much I like the 2.0’s. We went with some 29” Bighorn copies this time around for 1/2 the price and they so far have been excellent tires. We had a lot of sidewall punctures with factory Bighorns and so far so good with these 6pl copies.They are much more robust
I
IttyBittyFitty
45
72
Which copies did you go with?
322,690
These
2F2E7080 1D2E 4617 A5E2 C1E4ADD8DB13
You can tell how much more beefy they are, obviously this is comparing worn tread to new but the tread is thicker and taller then stock. Awesome tire. They were incredible this year in the snow. Went deep into the pokies with no problems.
AEE83410 F617 49B2 8A51 7F5E2524881A BD30F590 C80C 4727 A018 BDA62FF2E10E
dnjones161
dnjones161
583
1,713
Ohio
Wow those are a heck of a deal. I thought the Trilobite HDs were cheap (comparing to the Maxxis brand of course), but thats prolly another 100 dollars off the set. Good find @CumminsPusher
I'll be interested to hear what Maxxis comes up with as far as warrantying what you have. Honestly, it may be worth taking your warrantied tires and putting them on craigslist/equivalent and just ordering a set of those knock offs.
I put a little split in mine, not through the tire but enough to scare me, and decided I had better upgrade before I ruin a weekend with a flat. Its prolly going to be tough to get rid of them around here because they have the reputation for being too thin for the Pioneers, but I found a guy with a quad that was tickled to get a set of 4 gentle used bighorn's for 250 bucks. At that point you only have $100 ish dollars in a set of four brand new, heavier duty tires (plus mount if you have to pay- another 5 bucks/tire around here). Busting 1 factory tire is going to cost you well over 100 if you replace it with another "Honda-Maxxis" 4 ply bighorn through the dealer.
Food for thought...
Reactions: CumminsPusher
dnjones161
dnjones161
583
1,713
Ohio
Also I would note for chuckles- I had a gentleman approach me on multiple occasions about buying my take offs for his Ford Ranger...
I refused based on the application, but you never know who might be interested....
:D:D:D
These
View attachment 109615 View attachment 109617
That’s good to know CP because I can’t get anywhere in the snow over here in my stocker 2.0’s :rolleyes: Btw, do 29’s fit without lift or arched A arms?
322,690
You’d need arched front for these to get under
jwfirebird
jwfirebird
927
1,446
western ny
I always find the mud lights better in snow and clay for clearing, I got the 27X12s 350 I think they are 400 now. we have a ton of mud and deep snow, people I know with bighorns normally sell them, around here not even a good summer tire. as long as you don't ride the roads or rocks a ton, they ride smooth and handle decent too. the utv 2.0 is radial and rated for like 1k+LBS
two wheel drive stuff with these and not slipping
Mud Lite II
20181221 102928
20190120 124756
Reactions: Montecresto
Mud Lite II
That could be cool, I know that my OEM 2.0’s aren’t cleaning out the snow at all, which is why I’m getting stuck. How do they wear on hard pack?
Reactions: jwfirebird
