P1000 Bilge blower mounting
Jakey
81
139
San Francisco Bay Area
I'm going to install my bilge blower under the seat tomorrow. Any consensus on the best way to mount it? Any easy brackets without much fabrication? Thanks
By the way, I sure hope this helps because on long uphill climbs it gets HOT!!!!
sharp
sharp
3,757
14,955
Tennessee
The easiest way is to use long thick zip ties and zip tie it to the seat support bar.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Check out @snuffnwhisky or @Jshell3 build thread. They came up with some pretty mounts. I ran a piece of 1/8 x1/2 flat strap all the way across the seat pan so I could attach 2 blowers.
Jshell3
For the record, @Jakey I copied the idea like every idea I've had on my P1k5, from the talented members of this forum.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Piece of 1"x1/8" flat stock and U-bolt around round support bar is super easy.
Reactions: sharp
Jshell3
@Jakey
IMG 4599
IMG 4600
P1000m5 - BIG BLUE
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I did the aluminum bubble wrap from Lowe's under the seat to up the back seat, 1 pcs. Without the insulation, the blower didn't help me much if any. The insulation made a huge difference. I only run my fan if I'm sitting running for a while.
Jshell3
Agreed.
The back passengers seem to appreciate the blower.
I have the heat shield from @Bayouownbeer works good, too.
Prefabbed. Easy install. No waste.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Haven't tested the back seat. I do know without the insulation, with the fan, dynomat all around and my headers ceramic painted and wrapped, u could barely touch the plastic piece between the seats. No problem with just the insulation alone.
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Agreed.
Doesn't his stop at the plastic piece between the seats?
Reactions: sharp
Jakey
81
139
Final question, you guys are mounting the fan so it takes air from the front and blows back over the header and out the rear, correct?
sharp
sharp
3,757
14,955
Tennessee
Yes
Reactions: Jshell3
